Dear all,
No longer ago, I asked a topic about Detectron2 on TensorRT although the working environment was on Windows system.
- Link (Second part) : About Detectron2 on TensorRT
Currently, I have reproduced the issue on my TX2
Jetson device. Detectron2 is quite popular nowadays that it represents one of SOTA techniques. I wish that this issue can be paid attention because I believe many people wanna use the Detectron2 on TensorRT in Jetson devices as well.
Reproduce my issue:
Here I will show what I have tried the success part that it only includes Backbone+FPN part.
- Git clone Detectron2 and install setup.py (I was installing this version. Here)
- Go to
detectron2/tools
folder - Download
test_detect.py
(The document is here.) and put in (detectron2/tools
) folder - Open command line/terminal to (
detectron2/tools
) folder, and typepython3 test_detect.py
NOTE:
Check this : For detectron2 issue · GitHub
Please check the line 172 and line 173
below:
dummy_convert(cfg, only_backbone = True) # only backbone + FPN
dummy_convert(cfg, only_backbone = False) # all
If only_backbone = True
, you can convert it successfully that only with backbone + FPN.
However, if only_backbone = False
, it means including whole model that it will get wrong.
Error message:
Here is my entire output messages.
File "test_detect.py", line 173, in <module>
File "test_detect.py", line 152, in dummy_convert
export_params=True
File "/usr/local/lib/python3.6/dist-packages/torch/onnx/__init__.py", line 143, in export
strip_doc_string, dynamic_axes, keep_initializers_as_inputs)
File "/usr/local/lib/python3.6/dist-packages/torch/onnx/utils.py", line 66, in export
dynamic_axes=dynamic_axes, keep_initializers_as_inputs=keep_initializers_as_inputs)
File "/usr/local/lib/python3.6/dist-packages/torch/onnx/utils.py", line 382, in _export
fixed_batch_size=fixed_batch_size)
File "/usr/local/lib/python3.6/dist-packages/torch/onnx/utils.py", line 249, in _model_to_graph
graph, torch_out = _trace_and_get_graph_from_model(model, args, training)
File "/usr/local/lib/python3.6/dist-packages/torch/onnx/utils.py", line 206, in _trace_and_get_graph_from_model
trace, torch_out, inputs_states = torch.jit.get_trace_graph(model, args, _force_outplace=True, _return_inputs_states=True)
File "/usr/local/lib/python3.6/dist-packages/torch/jit/__init__.py", line 275, in get_trace_graph
return LegacyTracedModule(f, _force_outplace, return_inputs, _return_inputs_states)(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/torch/nn/modules/module.py", line 541, in __call__
result = self.forward(*input, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/torch/jit/__init__.py", line 355, in forward
out_vars, _ = _flatten(out)
RuntimeError: Only tuples, lists and Variables supported as JIT inputs/outputs. Dictionaries and strings are also accepted but their usage is not recommended. But got unsupported type Instances
We knew if we wanna use the model on TensorRT that we have to export the onnx model then converting onnx model to TensorRT engine. However, there are many functions in Detectron2 which were written by Python class
so that we cannot export the model to onnx model
because of Python class
issue.
Thank you.
Environment information
- Pytorch :
1.3.0
- Detectron2 :
0.1.1
- CUDA :
10.0
- Python :
3.6.9
- JetPack version :
4.3
- cuDNN version :
7.6.3
- cmake version :
3.10.2
- onnxruntime-gpu-tensorrt :
1.0.0
