Hey guys,
I’m adding to a litle project of mine, fiddling with CUDA. I’m getting along with the coding side of things, but compiling and linking is causing me grief. My makefile is as follows:
CC=gcc
NVCC=nvcc
CFLAGS=-lm -Wall -lpng -lz -fopenmp -lcudart -O3
OFLAGS=-o fractal
MFLAGS=-c
all: fractal
fractal: main.o arguments.o instance.o mandelbrot.o newton.o complex_type.o
$(CC) $(CFLAGS) $(OFLAGS) main.o arguments.o instance.o mandelbrot.o newton.o complex_type.o
main.o: main.c
$(CC) $(CFLAGS) $(MFLAGS) main.c
arguments.o: arguments.c
$(CC) $(CFLAGS) $(MFLAGS) arguments.c
instance.o: instance.c
$(CC) $(CFLAGS) $(MFLAGS) instance.c
mandelbrot.o: mandelbrot.cu
$(NVCC) $(MFLAGS) mandelbrot.cu
newton.o: newton.c
$(CC) $(CFLAGS) $(MFLAGS) newton.c
complex_type.o: complex_type.c
$(CC) $(CFLAGS) $(MFLAGS) complex_type.c
And, sure enough, the compiler gives me:
/usr/bin/ld: cannot find -lcudart
…which is a pretty common problem, apparently. I’ve tried various solutions, I’m not using -static, I’ve tried adding various paths to various config files, no luck. Any suggestion is welcome at this point, even if you think I’ve tried it, please suggest it: if only so we can check things off the list.
