I have got CUDA to work in WSL2 and docker. The tests in the guide run fine.
I installed Plex in docker and tried to transcode a video. Checking the logs NVDEC seems to work fine, but NVENC fails with this error:
[0x7f0e95ffb700] ERROR - [Transcode] [FFMPEG] - Cannot load libnvidia-encode.so.1
[0x7f0e95ffb700] ERROR - [Transcode] [FFMPEG] - The minimum required Nvidia driver for nvenc is 418.30 or newer
I used this docker cmd:
docker run -d
–name=plex
–restart=unless-stopped
–gpus=all
-p 32400:32400/tcp
-p 3005:3005/tcp
-p 8324:8324/tcp
-p 32469:32469/tcp
-p 1900:1900/udp
-p 32410:32410/udp
-p 32412:32412/udp
-p 32413:32413/udp
-p 32414:32414/udp
-h docker
-e ADVERTISE_IP=“http://192.168.1.6:32400/”
-e TZ=Europe/Paris
-e PLEX_CLAIM=claim-xxx
-e NVIDIA_VISIBLE_DEVICES=all
-e NVIDIA_DRIVER_CAPABILITIES=compute,video,utility
-e ADVERTISE_IP=http://192.168.1.6:32400/
-e ALLOWED_NETWORKS=192.168.1.0/24
-v $HOME/plex/config:/config
-v $HOME/plex/transcode:/transcode
-v /mnt/d/Video:/video
plexinc/pms-docker:plexpass
I also tested with an earlier Plex version (plexinc/pms-docker:1.20.1.3252-a78fef9a9), but got the same error.
I have the 465.42 driver installed in Windows. Is this a bug in Plex/FFMPEG, or is the correct driver version not forwarded to Plex correctly?
