I want accelerated ffmpeg encoding with “h264_nvenc” codec.
ffmpeg -i video.mp4 -vcodec h264_nvenc -crf 25 -acodec copy Output.mp4
The above code works fine in “nvcr.io/nvidia/tensorflow:19.10-py3”,
but in “nvcr.io/nvidia/cuda:10.1-cudnn7-devel-ubuntu18.04” it gives the following error message.
If i change h264_nvenc to default encoder the code works fine.
Cannot load libnvidia-encode.so.1
[h264_nvenc @ 0x55c3a426b1c0] The minimum required Nvidia driver for nvenc is 378.13 or newer
Why is this error occurring?
Please tell me how to fix the error!
Reproduce the problem situation
nvidia-docker run --gpus all -it --net=host -v /home/ubuntu/workspace/:/workspace -e DISPLAY=unix$DISPLAY nvcr.io/nvidia/cuda:10.1-devel-ubuntu18.04
apt-get update
apt-get install -y ffmpeg libsm6 libxext6 libxrender-dev
This is my nvidia-smi result.
root@ip-172-31-28-221:/workspace# nvidia-smi
Mon Mar 30 08:20:28 2020
| NVIDIA-SMI 418.87.01 Driver Version: 418.87.01 CUDA Version: 10.1 |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 31C P8 9W / 70W | 0MiB / 15079MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
