• Jetson AGX Xavier (Jetson / GPU) • DeepStream 4.0.2 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Hi I am now confused by somthing about rtsp setting in Source Grop
I have two rtsp streams, the first one is an live source from a camera, the stream format is rtsp://admin:password01!@192.168.9.199/h264/ch41/sub/av_stream.
The second is an playback rtsp stream from an NVR like rtsp://admin:password01!@192.168.198.51:554/Streaming/tracks/701?starttime=20200603T153900Z&endtime=20200603T155500Z, both codec are H264, and I can play two streams with VLC or Potplayer with no error occur. but only the live source can be acquired and do the inference. The playback streams will get an FPS of 0 and a black screen, no other errors occur.
log of running playback rtsp stream and the config file
It seems both of them are the same. So could you give me futher help?
By the way, You said I need to figure out the URI which can be played through uridecodebin. Does it mean some rtsp cannot played by uridecodebin? My two streams are same on paramas setting expect one is live camera and the other is playback from NVR. Does deepstream have some special limit for playback rtsp streams? Thank you.
I test as you told me. the live camera source can playback on screen. but the NVR streams have no window shown on screen, the log of two streams are same as former replay. But I am sure that both streams can played by several media players such as VLC and Potplayer. So is there any solutions of this? Does uridecodebin have some limit for playback streams from NVR?
Hi, thank you for your reply. But I have checked the stream info of my playback rtsp stream. The format is NV12, not RGB or BGR. Could it be some other reason?
The stream info is below. the media player is Potplayer
Hi Danel,
Thanks for your reply. I run the command but have an error, so no a.h264 streams are created. Here is the log. What can I do for your futher debug? Thank you for your help. Hope for your reply.
Thanks for your reply. Is there any special limit for a RTSP URI run with rtspsrc? We also have streams whhich can be played by both of these commads. Those are streams from live camera. But this streams from NVR playback cannot run by these command. Note that both streams from NVR or live camera can be played by VLC and Potplayer. Does it mean rtspsrc doen’t support these NVR playback streams?
You would need to figure out a valid URI which can be launnched through rtspsrc, or you are not able to leverage DeepStream SDK. May see if other users can share experience of using NVR.
