I’m using an rk3588 sbc and the gpu (GeForce RTX 3080 ) is connected via pcie 3x4
with open drivers
[ 7.401277] NVRM: Chipset not recognized (vendor ID 0x1d87, device ID 0x3588)
[ 7.401285] The NVIDIA GPU driver for AArch64 has not been qualified on this platform
and therefore it is not recommended or intended for use in any production
environment.
[ 10.842101] NVRM: s_vbiosPatchInterfaceData: Found pIntFaceHdr entry count: 0, expected 2
[ 10.842107] NVRM: s_vbiosPatchInterfaceData: too few interface entires found for FWSEC cmd 0x15
[ 10.842112] NVRM: s_prepareForFwsec_TU102: Falcon ucode from hs
[ 10.842114] NVRM: s_prepareForFwsec_TU102: failed to prepare interface data for FWSEC cmd 0x15: 0x25
[ 10.842116] NVRM: s_prepareForFwsec_TU102: (note: VBIOS version 94.02.71.40.83)
[ 10.842119] NVRM: nvCheckOkFailedNoLog: Check failed: Invalid data passed [NV_ERR_INVALID_DATA] (0x00000025) returned from kgspPrepareForBootstrap_HAL(pGpu, pKernelGsp, KGSP_BOOT_MODE_NORMAL) @ kernel_gsp.c:3664
[ 10.842171] NVRM: RmInitAdapter: Cannot initialize GSP firmware RM
[ 10.843941] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x62:0x25:2015)
[ 10.845693] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
would anyone let me the reason behind the “Cannot initialize GSP firmware RM” issue ?
I solved the chipset not recognized error in open kernel modules by adding my own chipset info.
With the proprietary modules I face only the following issue.
environment.
