Cannot install CUDA Tool Kit 8.0.61 with Quadro M1200
Hi All,
My Quadro M1200 Driver version is 375.86 and I get a warning stating “The graphics driver could not find compatible graphics hardware…it is suggested that you keep your existing driver and install the remaining portions of the CUDA Toolkit” while trying to install CUDA 8.0.61 on Windows 10.
When I click next, accept the Terms and Conditions, In options I see Display driver in Driver components it shows the new version of Display driver as 376.51 and the current version as 375.86.
Should I keep this and click on next or should I uncheck this option?
Please let me know if I will be able to use the Toolkit properly.
Thanks and Regards,
Deepak Kar
You should be able to keep your existing 375.86 driver. It should be compatible with CUDA 8.0.
Thanks txbob.
I ran the toolkit and updated the driver to 376.51. Creating a project on vs 2015 gives me an exception from HRESULT.
I will try to install vs 2015 update 3 and .net 3.5 as mentioned in other thread.
Will it work fine with vs 2017 evaluation version?
