Cannot install rapids
i tried to install rapids package with the conda command from rapids.ai website and i am running into this error
conda create -n rapids-24.12 -c rapidsai -c conda-forge -c nvidia \ rapids=24.12 python=3.12 ‘cuda-version>=12.0,<=12.5’ \ jupyterlab networkx nx-cugraph=24.12 dash ‘pytorch=*=cuda’ tensorflow
Channels:
  • rapidsai
  • conda-forge
  • nvidia
  • defaults
    Platform: win-64
    Collecting package metadata (repodata.json): done
    Solving environment: failed
LibMambaUnsatisfiableError: Encountered problems while solving:
  • nothing provides requested rapids 24.12**
  • nothing provides requested nx-cugraph 24.12**
  • nothing provides requested \
  • nothing provides _python_rc needed by python-3.12.0rc3-rc3_h2628c8c_1_cpython
Could not solve for environment specs
The following packages are incompatible
├─ \ does not exist (perhaps a typo or a missing channel);
├─ nx-cugraph 24.12** does not exist (perhaps a typo or a missing channel);
├─ python 3.12** is installable with the potential options
│ ├─ python [3.12.0|3.12.1|…|3.12.8], which can be installed;
│ ├─ python [3.12.0|3.12.1|…|3.12.8] would require
│ │ └─ python_abi 3.12.* _cp312, which can be installed;
│ └─ python 3.12.0rc3 would require
│ └─ _python_rc, which does not exist (perhaps a missing channel);
├─ pytorch * cuda is not installable because there are no viable options
│ ├─ pytorch 2.5.1 would require
│ │ └─ python >=3.9,<3.10.0a0 , which conflicts with any installable versions previously reported;
│ │ └─ python >=3.10,<3.11.0a0 , which conflicts with any installable versions previously reported;
│ │ └─ python >=3.11,<3.12.0a0 , which conflicts with any installable versions previously reported;
│ │ ├─ python >=3.12,<3.13.0a0 with the potential options
│ │ │ ├─ python [3.12.0|3.12.1|…|3.12.8], which can be installed;
│ │ │ └─ python [3.12.0|3.12.1|…|3.12.8], which can be installed (as previously explained);
_cp312, which requires
│ │ └─ python 3.12.
_cpython, which conflicts with any installable versions previously reported;
│ └─ pytorch 2.5.1 would require
│ └─ python_abi 3.13.
_cp313, which conflicts with any installable versions previously reported;
├─ rapids 24.12
└─ tensorflow is not installable because there are no viable options
├─ tensorflow [0.12.1|1.0.0|…|1.9.0] would require
│ └─ python [3.5* |3.5.* |>=3.5,<3.6.0a0 ], which conflicts with any installable versions previously reported;
├─ tensorflow [1.10.0|1.13.1|…|1.9.0] would require
│ ├─ python >=3.6,<3.7.0a0 , which conflicts with any installable versions previously reported;
│ └─ tensorflow-base [1.13.1 py36_4|1.13.1 py36_5|1.13.1 py36_6|1.13.1 py36_8|1.13.2 py36_0], which requires
│ └─ python >=3.6,<3.7.0a0 , which conflicts with any installable versions previously reported;
├─ tensorflow [1.13.1|1.14.0|…|2.9.1] would require
│ ├─ python [3.7.* |>=3.7,<3.8.0a0 ], which conflicts with any installable versions previously reported;
│ └─ tensorflow-base 1.13.1 py37_7, which requires
│ └─ python >=3.7,<3.8.0a0 , which conflicts with any installable versions previously reported;
├─ tensorflow 1.14.0 would require
│ └─ python_abi 3.7.* _cp37m, which conflicts with any installable versions previously reported;
│ └─ python_abi 3.6.
_cp36m, which conflicts with any installable versions previously reported;
├─ tensorflow [1.10.0|1.11.0|…|2.1.0] would require
│ └─ python [3.6
|3.6.* ], which conflicts with any installable versions previously reported;
├─ tensorflow [1.7.0|1.7.1|1.8.0] would require
│ └─ tensorflow-base [1.7.0 |1.7.1 |1.8.0 ] but there are no viable options
│ ├─ tensorflow-base [1.7.0|1.7.1|1.8.0] would require
│ │ └─ python >=3.5,<3.6.0a0 , which conflicts with any installable versions previously reported;
│ └─ tensorflow-base [1.13.1|1.13.2|1.7.0|1.7.1|1.8.0], which cannot be installed (as previously explained);
├─ tensorflow [2.10.0|2.8.2|2.9.1] would require
│ └─ python 3.10.* , which conflicts with any installable versions previously reported;
├─ tensorflow [2.10.0|2.3.0|…|2.9.1] would require
│ └─ python 3.8.* , which conflicts with any installable versions previously reported;
└─ tensorflow [2.10.0|2.5.0|2.6.0|2.8.2|2.9.1] would require
└─ python 3.9.* , which conflicts with any installable versions previously reported.
The error appears to be saying conda cannot find the packages and is unable to install them. Even though the conda install command i pasted is directly from rapids.ai
can someone please help,
I have updated conda to its best version and googling around didnt land me any help
my email: alaguraghul2005@gmail.com
discord: rg.412
Hi @a-steel-heart thanks for all the info here. I’ll reach out to the RAPIDS team and see if we can get to the bottom of this. Thanks, Sophie
Hi @a-steel-heart - it looks like you’re running on Windows. RAPIDS on Windows is only supported via WSL2. Please take a look at the WSL2 installation guide: Installation Guide - RAPIDS Docs Thanks!
Oh gosh, a major oversight on my part. Thank you so much for pointing out!
I see now it doesn’t say windows 11, rather it says “Windows 11 using a [WSL2 specific install]”.
I sincerely apologize, once again thanks!
No apologies needed - just pleased it was an easy fix! Best of luck and do reach out if you hit a bump in the road!
best,
Sophie
