Originally published at: https://developer.nvidia.com/blog/run-rapids-on-microsoft-windows-10-using-wsl-2-the-windows-subsystem-for-linux/
This post was originally published on the RAPIDS AI Blog. A tutorial to run your favorite Linux software, including NVIDIA CUDA, on Windows RAPIDS is now more accessible to Windows users! This post walks you through installing RAPIDS on Windows Subsystem for Linux (WSL). WSL is a Windows 10 feature that enables users to run…
The DEV channel is now moving onto Windows 11 builds. I just got access at work to the WIP DEV channel, so I’m assuming these instructions will work with Win11.
If I have time … :P I might be able to test on my home laptop … but would be nice to have the blog post updated if possible.
reporting back … Win11 DEV channel worked fine with the instructions provided. Just don’t follow the ‘CUDA on WSL guide’ too far … ;)
I followed the procedure in the article to install the Rapids on windows 11 with WSL2 and Nvidia driver.
but failed to import cudf.
I also carefully followed ‘CUDA on WSL guide’, and I can run docker …
does Rapids 22 support Nvidia T500 GPU on WSL2?
