Cannot set GraceHopper PowerCap over 700W
we have different GraceHopper compute nodes; some are QCT systems (i.e. QuantaGrid S74G-2U) and some others are Supermicro (i.e. ARS-111GL-NHR) systems.
As far as I understood the GraceHopper chip in all the machines should be the same, but we measure different performance values, which are lower in the latter systems with respect to the former.
We probably found the issue, which is related to the fact that on the Supermicro machines apparently there is 700W power cap, while this is set to 900W on the QCT machines:
QCT:
| NVIDIA-SMI 545.23.08              Driver Version: 545.23.08    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  GH200 480GB                    On  | 00000009:01:00.0 Off |                    0 |
| N/A   52C    P0             375W / 900W |   2382MiB / 97871MiB |     99%      Default |
|                                         |                      |             Disabled |
Supermicro:
| NVIDIA-SMI 575.57.08              Driver Version: 575.57.08      CUDA Version: 12.9     |
|   0  NVIDIA GH200 480GB             On  |   00000009:01:00.0 Off |                    0 |
| N/A   23C    P0             64W /  700W |       0MiB /  97871MiB |      0%      Default |
|                                         |                        |             Disabled |
From this post I see that also on the Supermicro machine we should have a 900W maximum power:
And nvidia-smi reports a default Max Power of 900W:
$ nvidia-smi -q -d POWER
==============NVSMI LOG==============
Timestamp : Mon Jun 30 14:39:54 2025
Driver Version : 575.57.08
CUDA Version : 12.9
Attached GPUs : 1
GPU 00000009:01:00.0
GPU Power Readings
Average Power Draw : 64.46 W
Instantaneous Power Draw : 64.34 W
Current Power Limit : 700.00 W
Requested Power Limit : 700.00 W
Default Power Limit : 900.00 W
Min Power Limit : 100.00 W
Max Power Limit : 900.00 W
Using nvidia-smi we can lower the power limit under 700W, but apparently we are not able to increase it to 900W:
# nvidia-smi -pl 600
Power limit for GPU 00000009:01:00.0 was set to 600.00 W from 700.00 W.
All done.
# nvidia-smi
| N/A   24C    P0             64W /  600W |       0MiB /  97871MiB |      0%      Default |
|                                         |                        |             Disabled |
# nvidia-smi -pl 900
Power limit for GPU 00000009:01:00.0 was set to 900.00 W from 600.00 W.
All done.
# nvidia-smi
| N/A   24C    P0             64W /  700W |       0MiB /  97871MiB |      0%      Default |
|                                         |                        |             Disabled |
Any ideas about what could be forcing a Power Cap of 700W on the Supermicro GraceHopper GPU?
Thanks,
Enrico
As a reference for other users, apparently there was another limit set into the BMC of the machine… do not know who may have set it, but the magic command to rise it to the maximum 900W is the following:
curl -k -u YOURBMCADMINUSER:YOURBMCPASSWORD --location --request PATCH https://YOURMACHINEBMCIP/redfish/v1/Systems/1/Processors/GPU_0/EnvironmentMetrics --header 'Content-Type: application/json' --data '{"PowerLimitWatts": {"SetPoint": 900}}'
Then nvidia-smi can be used to increase it to 900W as well.
