Platform: Jetson AGX Orin
JetPack version: 6.2.1
Carrier board: Forecr DSBOARD-AGXMAX
Issue: SFP+ port (sfp0) fails to come up with PCS block lock error
I’m trying to use the SFP+ port on the DSBOARD-AGXMAX carrier board to achieve 10 Gb/s data offloading speeds. However, the port fails to initialize even with nothing plugged in (no transceiver module installed).
When bringing the interface up:
sudo ip link set sfp0 up
I get this kernel error:
nvethernet 6800000.ethernet: [xpcs_lane_bring_up][470][type:0x4][loga-0x0] Failed to get PCS block lock
The interface shows:
$ ethtool sfp0
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: on
Link detected: no
Questions:
- Does the SFP+ port require specific device tree configuration or firmware for the DSBOARD-AGXMAX carrier board?
- Is there a known issue with PCS block lock on JetPack 6.2.1?
- Are there any required kernel modules or driver parameters for SFP+ operation?
- Should the port work without a transceiver installed, or does it need one to initialize properly?
Any guidance would be appreciated. Thank you.
