I am unable to run a simple gstreamer pipeline that uses nveglglessink with wayland on L4T 36.4.0. This previously worked on L4T 35.4
I have started westion using nvstart-weston.sh, which is using the default desktop-shell.so.
If I run the following command gst-launch-1.0 videotestsrc ! video/x-raw,framerate=30/1,width=1920,height=1080 ! nveglglessink winsys=wayland, it fails to initialise eglglessink with error
0:00:00.033049467 1331 0xaaaaea353790 ERROR eglglessink-platform video_platform_wrapper.c:211:platform_initialize_display_wayland: Can't find compositor or shell
By enabled WAYLAND_DEBUG=1, the problem seems to be that the wl_registry does not provide wl_shell, which is required by nveglglessink. A bit of searching appears to indicate that wl_shell is deprecated, and clients should use xdg_shell / xdg_wm_base instead.
Is this a known issue with L4T 36.4.0?
