@lhoang, I’ve been investigating and the results are curiouser and curiouser!
First I modified the run_flash_command_on_target function to use ssh-keyscan to connect and record the device’s ssh keys, and use them as a user’s “known hosts” files:
run_flash_commmand_on_target()
set -x
echo "Run command: flash on ${1}"
local OLD_LC_ALL="${LC_ALL}"
local OLD_LANG="${LANG}"
local OLD_LANGUAGE="${LANGUAGE}"
export LC_ALL="" LANG="en_US.UTF-8" LANGUAGE=""
local cmd=()
local hosts_file=$(mktemp)
SSH_OPT_EXTRA=( -oUserKnownHostsFile="${hosts_file}" -vvv )
if [ -n "${target_partname}" ]; then
cmd+=("-k" "${target_partname}")
fi
if [ -n "${external_only}" ]; then
cmd+=("${external_only}")
fi
count=0
maxcount=10
echo ">>> DEBUG 'root@${1}' <<<"
while ! ssh-keyscan -T 1 "${1}" > "${hosts_file}"
do
echo -n ">>> nmap ${1} port 22 <<< " ; nmap -6 -p 22 --host-timeout 0.5 "${1}" | grep ssh
count=$((count + 1))
if [ "${count}" -ge "${maxcount}" ]; then
echo "SSH is not ready"
exit 1
fi
sleep 1
done
echo ">>> DEBUG contents of ${hosts_file} <<<"
cat "${hosts_file}"
if [ -e "${L4T_INITRD_FLASH_DIR}/bin/aarch64/simg2img" ]; then
cp "${L4T_INITRD_FLASH_DIR}/bin/aarch64/simg2img" "${NFS_IMAGES_DIR}"
fi
if ! sshpass -p root ssh "root@${1}" "${SSH_OPT[@]}" "${SSH_OPT_EXTRA[@]}" "NFS_ROOTFS_DIR=\"${NFS_ROOTFS_DIR}\" NFS_IMAGES_DIR=\"${NFS_IMAGES_DIR}\" /bin/${FLASH_FROM_NETWORK_SCRIPT} ${cmd[*]}"; then
echo "Flash failure"
exit 1
fi
if ! sshpass -p root ssh "root@${1}" "${SSH_OPT[@]}" "${SSH_OPT_EXTRA[@]}" "nohup reboot &>/dev/null & exit"; then
echo "Reboot failure"
exit 1
fi
export LC_ALL="${OLD_LC_ALL}" LANG="${OLD_LANG}" LANGUAGE="${OLD_LANGUAGE}"
set +x
This works as expected and lets us move to the next phase.
At this point, we are correctly talking to the sshd of the recovery device, but cannot log in with the password root.
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...+ echo 'Run command: flash on fc00:1:1:0::2'
+ local OLD_LC_ALL=
+ local OLD_LANG=en_US.UTF-8
+ local OLD_LANGUAGE=
+ export LC_ALL= LANG=en_US.UTF-8 LANGUAGE=
+ LC_ALL=
+ LANG=en_US.UTF-8
+ LANGUAGE=
+ cmd=()
+ local cmd
++ mktemp
+ local hosts_file=/tmp/tmp.hyEIV2hQX6
+ SSH_OPT_EXTRA=(-oUserKnownHostsFile="${hosts_file}" -vvv)
+ '[' -n '' ']'
+ '[' -n '' ']'
+ count=0
+ maxcount=10
+ echo '>>> DEBUG '\''root@fc00:1:1:0::2'\'' <<<'
>>> DEBUG 'root@fc00:1:1:0::2' <<<
+ ssh-keyscan -T 1 fc00:1:1:0::2
# fc00:1:1:0::2:22 SSH-2.0-OpenSSH_8.2p1 Ubuntu-4ubuntu0.7
+ echo '>>> DEBUG contents of /tmp/tmp.hyEIV2hQX6 <<<'
+ cat /tmp/tmp.hyEIV2hQX6
fc00:1:1:0::2 ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBOmh+T7E7zuPe5bARIVjEQxkj4WEunDc2CqnHRhbsD5R5VI9mNdUAWM5h0MgibjX+wVhNrEUalZ0i4ahTVGfCqo=
fc00:1:1:0::2 ssh-rsa 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
fc00:1:1:0::2 ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIJx0jsQRgq/tRO5jXZ+1RMzUgP3pWtpLPK26UuWiDdLz
+ '[' -e /home/andrew/Local/nvidia/nvidia-linux-for-tegra/nvidia-l4t-board-support-packages/tools/kernel_flash/bin/aarch64/simg2img ']'
+ cp /home/andrew/Local/nvidia/nvidia-linux-for-tegra/nvidia-l4t-board-support-packages/tools/kernel_flash/bin/aarch64/simg2img /home/andrew/Local/nvidia/nvidia-linux-for-tegra/nvidia-l4t-board-support-packages/tools/kernel_flash/images
+ sshpass -p root ssh root@fc00:1:1:0::2 -q -oServerAliveInterval=90 -oServerAliveCountMax=3 -oStrictHostKeyChecking=no -oUserKnownHostsFile=/dev/null -oUserKnownHostsFile=/tmp/tmp.hyEIV2hQX6 -vvv 'NFS_ROOTFS_DIR="/home/andrew/Local/nvidia/nvidia-linux-for-tegra/nvidia-l4t-board-support-packages/rootfs" NFS_IMAGES_DIR="/home/andrew/Local/nvidia/nvidia-linux-for-tegra/nvidia-l4t-board-support-packages/tools/kernel_flash/images" /bin/nv_flash_from_network.sh '
OpenSSH_8.9p1 Ubuntu-3ubuntu0.1, OpenSSL 3.0.2 15 Mar 2022
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug2: resolve_canonicalize: hostname fc00:1:1:0::2 is address
debug2: resolve_canonicalize: canonicalised address "fc00:1:1:0::2" => "fc00:1:1::2"
debug3: ssh_connect_direct: entering
debug1: Connecting to fc00:1:1::2 [fc00:1:1::2] port 22.
debug3: set_sock_tos: set socket 3 IPV6_TCLASS 0x10
debug1: Connection established.
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa type -1
debug1: identity file /root/.ssh/id_ecdsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa_sk type -1
debug1: identity file /root/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /root/.ssh/id_ed25519 type -1
debug1: identity file /root/.ssh/id_ed25519-cert type -1
debug1: identity file /root/.ssh/id_ed25519_sk type -1
debug1: identity file /root/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /root/.ssh/id_xmss type -1
debug1: identity file /root/.ssh/id_xmss-cert type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: identity file /root/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.1
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.7
debug1: compat_banner: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.7 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to fc00:1:1::2:22 as 'root'
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug3: order_hostkeyalgs: no algorithms matched; accept original
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,sntrup761x25519-sha512@openssh.com,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c
debug2: host key algorithms: ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,rsa-sha2-512,rsa-sha2-256
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256
debug2: host key algorithms: rsa-sha2-512,rsa-sha2-256,ssh-rsa,ecdsa-sha2-nistp256,ssh-ed25519
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:cqcP2ox6TZSW4RC+mdKWZzjAVqUPkaCbVIRzufHiQos
Warning: Permanently added 'fc00:1:1::2' (ED25519) to the list of known hosts.
debug3: send packet: type 21
debug2: ssh_set_newkeys: mode 1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: ssh_set_newkeys: mode 0
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /root/.ssh/id_rsa
debug1: Will attempt key: /root/.ssh/id_ecdsa
debug1: Will attempt key: /root/.ssh/id_ecdsa_sk
debug1: Will attempt key: /root/.ssh/id_ed25519
debug1: Will attempt key: /root/.ssh/id_ed25519_sk
debug1: Will attempt key: /root/.ssh/id_xmss
debug1: Will attempt key: /root/.ssh/id_dsa
debug2: pubkey_prepare: done
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue:
debug3: start over, passed a different list gssapi-with-mic,publickey,keyboard-interactive,password
debug3: preferred gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup gssapi-with-mic
debug3: remaining preferred: publickey,keyboard-interactive,password
debug3: authmethod_is_enabled gssapi-with-mic
debug1: Next authentication method: gssapi-with-mic
debug1: No credentials were supplied, or the credentials were unavailable or inaccessible
No Kerberos credentials available (default cache: FILE:/tmp/krb5cc_0)
debug2: we did not send a packet, disable method
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /root/.ssh/id_rsa
debug3: no such identity: /root/.ssh/id_rsa: No such file or directory
debug1: Trying private key: /root/.ssh/id_ecdsa
debug3: no such identity: /root/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /root/.ssh/id_ecdsa_sk
debug3: no such identity: /root/.ssh/id_ecdsa_sk: No such file or directory
debug1: Trying private key: /root/.ssh/id_ed25519
debug3: no such identity: /root/.ssh/id_ed25519: No such file or directory
debug1: Trying private key: /root/.ssh/id_ed25519_sk
debug3: no such identity: /root/.ssh/id_ed25519_sk: No such file or directory
debug1: Trying private key: /root/.ssh/id_xmss
debug3: no such identity: /root/.ssh/id_xmss: No such file or directory
debug1: Trying private key: /root/.ssh/id_dsa
debug3: no such identity: /root/.ssh/id_dsa: No such file or directory
debug3: authmethod_lookup keyboard-interactive
debug3: remaining preferred: password
debug3: authmethod_is_enabled keyboard-interactive
debug1: Next authentication method: keyboard-interactive
debug2: userauth_kbdint
debug2: we sent a keyboard-interactive packet, wait for reply
debug3: userauth_kbdint: disable: no info_req_seen
debug3: authmethod_lookup password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
debug2: we sent a password packet, wait for reply
Permission denied, please try again.
+ echo 'Flash failure'
Flash failure
The full log is here: flash-emmc-ssh-keyscan.log (197.3 KB)
Now here is the funny part.
I can verify the password for root is root on the device via the console:
bash-5.0# cat /etc/shadow
root:$6$qYzNFHlg$M4RG6AtkTS3kj1/Al2WqoRvUxWL9mFRjUadC74qSBhgWtkRjtVtiZJpJvAaG4DEHnJKSnOVwX4fHCt0A7vtXR/:18192:0:99999:7:::
sshd:\*:17669:0:99999:7:::
and
$ mkpasswd -m sha-512 -S 'qYzNFHlg' root
and I have verified that this is the same password in the ota_tools directory.
I can verify that fc00:1:1:0::2 is the device and is connected to the sshd daemon, by kill -STOP ... and kill -CONT ... on the device.
However trying to ssh from the host to the device manually connects but password authentication fails.
On the host, using
ssh -vvv -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null -v root@fc00:1:1:0::2 /usr/bin/echo hello
results in “permission denied”
debug1: Reading configuration data /home/andrew/.ssh/config
debug1: /home/andrew/.ssh/config line 50: Applying options for *
debug1: identity file /home/andrew/.ssh/id_rsa type 0
debug1: identity file /home/andrew/.ssh/id_rsa-cert type -1
debug2: compression ctos: zlib@openssh.com,zlib,none
debug2: compression stoc: zlib@openssh.com,zlib,none
debug2: reserved 0
debug2: reserved 0
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: zlib@openssh.com
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: zlib@openssh.com
debug2: get_agent_identities: ssh_agent_bind_hostkey: agent refused operation
debug1: get_agent_identities: ssh_fetch_identitylist: agent contains no identities
debug1: Will attempt key: /home/andrew/.ssh/id_rsa RSA SHA256:OLct8o8JRFiX/TDDTGP9lc1rUiw7vlS/CWw0YeQeC2g explicit
No Kerberos credentials available (default cache: FILE:/tmp/krb5cc_1000)
debug1: Offering public key: /home/andrew/.ssh/id_rsa RSA SHA256:OLct8o8JRFiX/TDDTGP9lc1rUiw7vlS/CWw0YeQeC2g explicit
debug2: we sent a publickey packet, wait for reply
root@fc00:1:1::2's password:
debug1: No more authentication methods to try.
root@fc00:1:1::2: Permission denied ().
On the device, the sshd logs are not helpful:
bash-5.0# cat /etc/
bash-5.0# cat /tmp/sshd.log
Server listening on :: port 22.
Server listening on 0.0.0.0 port 22.
Connection closed by fc00:1:1::1 port 36418 [preauth]
Connection closed by fc00:1:1::1 port 36414 [preauth]
Connection closed by fc00:1:1::1 port 36428 [preauth]
Unable to negotiate with fc00:1:1::1 port 36430: no matching host key type found. Their offer: sk-ecdsa-sha2-nistp256@openssh.com [preauth]
Unable to negotiate with fc00:1:1::1 port 36434: no matching host key type found. Their offer: sk-ssh-ed25519@openssh.com [preauth]
Connection closed by authenticating user root fc00:1:1::1 port 36446 [preauth]
Connection closed by authenticating user root fc00:1:1::1 port 43914 [preauth]
I have tried appending LogLevel DEBUG3 to /etc/ssh/sshd_config and kill -HUP ... the sshd, but there is no increase in useful information.
I have tried manually changing the root password on the device in the recovery initrd, but cannot:
bash-5.0# passwd
passwd: pam_start() failed, error 26
And I have verified that sshd is not using PAM:
bash-5.0# grep -i pam /etc/ssh/sshd_config
# ... comments removed
UsePAM no
I am at a loss as to how to proceed with debugging this issue at this point.
