I am trying to build the 390.xx drivers on Fedora 30 using the akmod packages from rpmfusion. I’m using kernel 5.3.9-200.fc30.x86_64. The build fails with the following errors:
2019/11/11 16:29:57 akmods: Building RPM using the command '/sbin/akmodsbuild --kernels 5.3.9-200.fc30.x86_64 /usr/src/akmods/nvidia-390xx-kmod.latest'
In file included from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-linux.h:136,
from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.c:13:
/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-list-helpers.h:94:19: error: redefinition of 'list_is_first'
94 | static inline int list_is_first(const struct list_head *list,
In file included from ./include/linux/preempt.h:11,
from ./include/linux/spinlock.h:51,
from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-lock.h:16,
from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-linux.h:19,
./include/linux/list.h:245:19: note: previous definition of 'list_is_first' was here
245 | static inline int list_is_first(const struct list_head *list,
make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-gpu-numa.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-frontend.o] Error 1
make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.o] Error 1
make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv.o] Error 1
make[1]: *** [Makefile:1630: _module_/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.3.9-200.fc30.x86_64'
make: *** [Makefile:79: modules] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.rliDHg (%build)
RPM build errors:
user mockbuild does not exist - using root
group mock does not exist - using root
2019/11/11 16:30:10 akmodsbuild: * Rebuilding /usr/src/akmods/nvidia-390xx-kmod.latest for kernel(s) 5.3.9-200.fc30.x86_64: warning: user mockbuild does not exist - using root
2019/11/11 16:30:10 akmodsbuild: warning: group mock does not exist - using root
2019/11/11 16:30:10 akmodsbuild: warning: user mockbuild does not exist - using root
2019/11/11 16:30:10 akmodsbuild: Installing /usr/src/akmods/nvidia-390xx-kmod.latest
2019/11/11 16:30:10 akmodsbuild: Building target platforms: x86_64
2019/11/11 16:30:10 akmodsbuild: Building for target x86_64
2019/11/11 16:30:10 akmodsbuild: Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.9CvDQQ
2019/11/11 16:30:10 akmodsbuild: + umask 022
2019/11/11 16:30:10 akmodsbuild: + cd /tmp/akmodsbuild.rGFUWFzm//BUILD
2019/11/11 16:30:10 akmodsbuild: + kmodtool --target x86_64 --repo rpmfusion --kmodname nvidia-390xx-kmod --filterfile /tmp/akmodsbuild.rGFUWFzm/SOURCES/nvidia-390xx-kmodtool-excludekernel-filterfile --akmod --for-kernels 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: %global _prefix_usr /usr
2019/11/11 16:30:10 akmodsbuild: %if 0%{?rhel}
2019/11/11 16:30:10 akmodsbuild: %package -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: Summary: nvidia-390xx kernel module(s) for 5.3.9-200.fc30
2019/11/11 16:30:10 akmodsbuild: Provides: kernel-modules = 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: Provides: nvidia-390xx-kmod = %{?epoch:%{epoch}:}%{version}-%{release}
2019/11/11 16:30:10 akmodsbuild: Requires: nvidia-390xx-kmod-common >= %{?epoch:%{epoch}:}%{version}
2019/11/11 16:30:10 akmodsbuild: Requires(post): %{?_prefix_usr}/sbin/weak-modules
2019/11/11 16:30:10 akmodsbuild: Requires(post): %{?_prefix_usr}/sbin/depmod
2019/11/11 16:30:10 akmodsbuild: Requires(postun): %{?_prefix_usr}/sbin/weak-modules
2019/11/11 16:30:10 akmodsbuild: Requires(postun): %{?_prefix_usr}/sbin/depmod
2019/11/11 16:30:10 akmodsbuild: %else
2019/11/11 16:30:10 akmodsbuild: Summary: nvidia-390xx kernel module(s) for 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: Provides: kernel-modules-for-kernel = 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: %endif
2019/11/11 16:30:10 akmodsbuild: %global _kmodtool_depmod_post if [ -f /boot/System.map-5.3.9-200.fc30.x86_64 ] ; then %{?_prefix_usr}/sbin/depmod -aeF /boot/System.map-5.3.9-200.fc30.x86_64 5.3.9-200.fc30.x86_64 >/dev/null ; elif [ -f /lib/modules/5.3.9-200.fc30.x86_64/System.map ] ; then %{?_prefix_usr}/sbin/depmod -aeF /lib/modules/5.3.9-200.fc30.x86_64/System.map 5.3.9-200.fc30.x86_64 >/dev/null ; else %{?_prefix_usr}/sbin/depmod -a >/dev/null ; fi || :
2019/11/11 16:30:10 akmodsbuild: Requires: kernel >= 5.3.9-200.fc30
2019/11/11 16:30:10 akmodsbuild: Requires: kernel < 5.3.9-201.fc30
2019/11/11 16:30:10 akmodsbuild: BuildRequires: kernel-devel = 5.3.9-200.fc30 redhat-rpm-config kernel-abi-whitelists
2019/11/11 16:30:10 akmodsbuild: %post -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: %{_kmodtool_depmod_post}
2019/11/11 16:30:10 akmodsbuild: modules=( $(find /usr/lib/modules/5.3.9-200.fc30.x86_64/extra/nvidia-390xx/ | grep -e '.ko$') )
2019/11/11 16:30:10 akmodsbuild: printf '%sn' "${modules[@]}" | %{?_prefix_usr}/sbin/weak-modules --add-modules
2019/11/11 16:30:10 akmodsbuild: %preun -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: rpm -ql kmod-nvidia-390xx-5.3.9-200.fc30.x86_64-%{version}-%{release}.x86_64 | grep -e '.ko$' > /var/run/rpm-kmod-nvidia-390xx-modules
2019/11/11 16:30:10 akmodsbuild: %postun -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: modules=( $(cat /var/run/rpm-kmod-nvidia-390xx-modules) )
2019/11/11 16:30:10 akmodsbuild: rm /var/run/rpm-kmod-nvidia-390xx-modules
2019/11/11 16:30:10 akmodsbuild: printf '%sn' "${modules[@]}" | %{?_prefix_usr}/sbin/weak-modules --remove-modules
2019/11/11 16:30:10 akmodsbuild: Requires: kernel-uname-r = 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: BuildRequires: kernel-devel-uname-r = 5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: BuildRequires: gcc
2019/11/11 16:30:10 akmodsbuild: %description -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: This package provides the nvidia-390xx kernel modules built for the Linux
2019/11/11 16:30:10 akmodsbuild: kernel 5.3.9-200.fc30 for the %{_target_cpu} family of processors.
2019/11/11 16:30:10 akmodsbuild: %files -n kmod-nvidia-390xx-5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: %defattr(644,root,root,755)
2019/11/11 16:30:10 akmodsbuild: %dir /usr/lib/modules/5.3.9-200.fc30.x86_64/extra
2019/11/11 16:30:10 akmodsbuild: /usr/lib/modules/5.3.9-200.fc30.x86_64/extra/nvidia-390xx/
2019/11/11 16:30:10 akmodsbuild: kernel 5.3.9-200.fc30.x86_64 for the %{_target_cpu} family of processors.
2019/11/11 16:30:10 akmodsbuild: %global kmodinstdir_prefix /usr/lib/modules/
2019/11/11 16:30:10 akmodsbuild: %global kmodinstdir_postfix /extra/nvidia-390xx/
2019/11/11 16:30:10 akmodsbuild: %global kernel_versions 5.3.9-200.fc30.x86_64___%{_usrsrc}/kernels/5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: %global debug_package %{nil}
2019/11/11 16:30:10 akmodsbuild: + cd /tmp/akmodsbuild.rGFUWFzm/BUILD
2019/11/11 16:30:10 akmodsbuild: + rm -rf nvidia-390xx-kmod-390.116
2019/11/11 16:30:10 akmodsbuild: + /usr/bin/mkdir -p nvidia-390xx-kmod-390.116
2019/11/11 16:30:10 akmodsbuild: + cd nvidia-390xx-kmod-390.116
2019/11/11 16:30:10 akmodsbuild: + /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
2019/11/11 16:30:10 akmodsbuild: + tar --use-compress-program xz -xf /usr/share/nvidia-390xx-kmod-390.116/nvidia-390xx-kmod-390.116-x86_64.tar.xz
2019/11/11 16:30:10 akmodsbuild: + echo 'Patch #0 (nv-linux-arm.patch):'
2019/11/11 16:30:10 akmodsbuild: Patch #0 (nv-linux-arm.patch):
2019/11/11 16:30:10 akmodsbuild: + /usr/bin/patch --no-backup-if-mismatch -p1 --fuzz=0
2019/11/11 16:30:10 akmodsbuild: patching file kernel/common/inc/nv-linux.h
2019/11/11 16:30:10 akmodsbuild: Hunk #1 succeeded at 281 (offset 21 lines).
2019/11/11 16:30:10 akmodsbuild: + echo 'Patch #1 (nv-linux-arm2.patch):'
2019/11/11 16:30:10 akmodsbuild: Patch #1 (nv-linux-arm2.patch):
2019/11/11 16:30:10 akmodsbuild: Hunk #1 succeeded at 178 (offset 22 lines).
2019/11/11 16:30:10 akmodsbuild: + for kernel_version in 5.3.9-200.fc30.x86_64___/usr/src/kernels/5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: + cp -a kernel _kmod_build_5.3.9-200.fc30.x86_64
2019/11/11 16:30:10 akmodsbuild: + exit 0
2019/11/11 16:30:10 akmodsbuild: Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.rliDHg
2019/11/11 16:30:10 akmodsbuild: + pushd _kmod_build_5.3.9-200.fc30.x86_64/
2019/11/11 16:30:10 akmodsbuild: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116
2019/11/11 16:30:10 akmodsbuild: + make V=1 -j4 KERNEL_UNAME=5.3.9-200.fc30.x86_64 SYSSRC=/usr/src/kernels/5.3.9-200.fc30.x86_64 IGNORE_CC_MISMATCH=1 IGNORE_XEN_PRESENCE=1 IGNORE_PREEMPT_RT_PRESENCE=1 module
2019/11/11 16:30:10 akmodsbuild: make[1]: Entering directory '/usr/src/kernels/5.3.9-200.fc30.x86_64'
2019/11/11 16:30:10 akmodsbuild: test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( echo >&2; echo >&2 " ERROR: Kernel configuration is invalid."; echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; echo >&2 ; /bin/false)
2019/11/11 16:30:10 akmodsbuild: make -f ./scripts/Makefile.build obj=/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 need-modorder=1
2019/11/11 16:30:10 akmodsbuild: ln -sf /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-kernel.o_binary /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-kernel.o
2019/11/11 16:30:10 akmodsbuild: ln -sf /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia-modeset/nv-modeset-kernel.o_binary /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia-modeset/nv-modeset-kernel.o
2019/11/11 16:30:10 akmodsbuild: { echo /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia.ko; echo /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia-uvm.ko; echo /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia-modeset.ko; echo /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia-drm.ko; :; } | awk '!x[$0]++' - > /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/modules.order
2019/11/11 16:30:10 akmodsbuild: CONFTEST: INIT_WORK
2019/11/11 16:30:10 akmodsbuild: CONFTEST: remap_pfn_range
2019/11/11 16:30:10 akmodsbuild: CONFTEST: hash__remap_4k_pfn
2019/11/11 16:30:10 akmodsbuild: CONFTEST: follow_pfn
2019/11/11 16:30:10 akmodsbuild: CONFTEST: vmap
2019/11/11 16:30:10 akmodsbuild: CONFTEST: set_pages_uc
2019/11/11 16:30:10 akmodsbuild: CONFTEST: set_memory_uc
2019/11/11 16:30:10 akmodsbuild: CONFTEST: set_memory_array_uc
2019/11/11 16:30:10 akmodsbuild: CONFTEST: change_page_attr
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_get_class
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_choose_state
2019/11/11 16:30:10 akmodsbuild: CONFTEST: vm_insert_page
2019/11/11 16:30:10 akmodsbuild: CONFTEST: acpi_device_id
2019/11/11 16:30:10 akmodsbuild: CONFTEST: acquire_console_sem
2019/11/11 16:30:10 akmodsbuild: CONFTEST: console_lock
2019/11/11 16:30:10 akmodsbuild: CONFTEST: kmem_cache_create
2019/11/11 16:30:10 akmodsbuild: CONFTEST: on_each_cpu
2019/11/11 16:30:10 akmodsbuild: CONFTEST: smp_call_function
2019/11/11 16:30:10 akmodsbuild: CONFTEST: acpi_evaluate_integer
2019/11/11 16:30:10 akmodsbuild: CONFTEST: ioremap_cache
2019/11/11 16:30:10 akmodsbuild: CONFTEST: ioremap_wc
2019/11/11 16:30:10 akmodsbuild: CONFTEST: acpi_walk_namespace
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_domain_nr
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_dma_mapping_error
2019/11/11 16:30:10 akmodsbuild: CONFTEST: sg_alloc_table
2019/11/11 16:30:10 akmodsbuild: CONFTEST: sg_init_table
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_get_domain_bus_and_slot
2019/11/11 16:30:10 akmodsbuild: CONFTEST: get_num_physpages
2019/11/11 16:30:10 akmodsbuild: CONFTEST: efi_enabled
2019/11/11 16:30:10 akmodsbuild: CONFTEST: proc_create_data
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pde_data
2019/11/11 16:30:10 akmodsbuild: CONFTEST: proc_remove
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pm_vt_switch_required
2019/11/11 16:30:10 akmodsbuild: CONFTEST: xen_ioemu_inject_msi
2019/11/11 16:30:10 akmodsbuild: CONFTEST: phys_to_dma
2019/11/11 16:30:10 akmodsbuild: CONFTEST: get_dma_ops
2019/11/11 16:30:10 akmodsbuild: CONFTEST: write_cr4
2019/11/11 16:30:10 akmodsbuild: CONFTEST: of_get_property
2019/11/11 16:30:10 akmodsbuild: CONFTEST: of_find_node_by_phandle
2019/11/11 16:30:10 akmodsbuild: CONFTEST: of_node_to_nid
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pnv_pci_get_npu_dev
2019/11/11 16:30:10 akmodsbuild: CONFTEST: for_each_online_node
2019/11/11 16:30:10 akmodsbuild: CONFTEST: node_end_pfn
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_bus_address
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_stop_and_remove_bus_device
2019/11/11 16:30:10 akmodsbuild: CONFTEST: pci_remove_bus_device
2019/11/11 16:30:10 akmodsbuild: CONFTEST: request_threaded_irq
2019/11/11 16:30:10 akmodsbuild: CONFTEST: register_cpu_notifier
2019/11/11 16:30:10 akmodsbuild: CONFTEST: cpuhp_setup_state
2019/11/11 16:30:10 akmodsbuild: CONFTEST: dma_map_resource
2019/11/11 16:30:10 akmodsbuild: CONFTEST: backlight_device_register
2019/11/11 16:30:10 akmodsbuild: CONFTEST: register_acpi_notifier
2019/11/11 16:30:10 akmodsbuild: CONFTEST: timer_setup
2019/11/11 16:30:10 akmodsbuild: CONFTEST: kmem_cache_create_usercopy
2019/11/11 16:30:10 akmodsbuild: CONFTEST: do_gettimeofday
2019/11/11 16:30:10 akmodsbuild: CONFTEST: remap_page_range
2019/11/11 16:30:10 akmodsbuild: CONFTEST: address_space_init_once
2019/11/11 16:30:10 akmodsbuild: CONFTEST: kbasename
2019/11/11 16:30:10 akmodsbuild: CONFTEST: fatal_signal_pending
2019/11/11 16:30:10 akmodsbuild: CONFTEST: list_cut_position
2019/11/11 16:30:10 akmodsbuild: CONFTEST: vzalloc
2019/11/11 16:30:10 akmodsbuild: CONFTEST: wait_on_bit_lock_argument_count
2019/11/11 16:30:10 akmodsbuild: CONFTEST: bitmap_clear
2019/11/11 16:30:10 akmodsbuild: CONFTEST: usleep_range
2019/11/11 16:30:10 akmodsbuild: CONFTEST: radix_tree_empty
2019/11/11 16:30:10 akmodsbuild: CONFTEST: radix_tree_replace_slot
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_dev_unref
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_reinit_primary_mode_group
2019/11/11 16:30:10 akmodsbuild: CONFTEST: get_user_pages_remote
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_gem_object_lookup
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_atomic_state_free
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_driver_has_gem_prime_res_obj
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_atomic_helper_connector_dpms
2019/11/11 16:30:10 akmodsbuild: CONFTEST: drm_connector_funcs_have_mode_in_name
2019/11/11 16:30:11 akmodsbuild: CONFTEST: vmf_insert_pfn
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_framebuffer_get
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_gem_object_get
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_dev_put
2019/11/11 16:30:11 akmodsbuild: CONFTEST: is_export_symbol_gpl_of_node_to_nid
2019/11/11 16:30:11 akmodsbuild: CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
2019/11/11 16:30:11 akmodsbuild: CONFTEST: is_export_symbol_present_swiotlb_dma_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: i2c_adapter
2019/11/11 16:30:11 akmodsbuild: CONFTEST: pm_message_t
2019/11/11 16:30:11 akmodsbuild: CONFTEST: irq_handler_t
2019/11/11 16:30:11 akmodsbuild: CONFTEST: acpi_device_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: acpi_op_remove
2019/11/11 16:30:11 akmodsbuild: CONFTEST: outer_flush_all
2019/11/11 16:30:11 akmodsbuild: CONFTEST: proc_dir_entry
2019/11/11 16:30:11 akmodsbuild: CONFTEST: scatterlist
2019/11/11 16:30:11 akmodsbuild: CONFTEST: sg_table
2019/11/11 16:30:11 akmodsbuild: CONFTEST: file_operations
2019/11/11 16:30:11 akmodsbuild: CONFTEST: vm_operations_struct
2019/11/11 16:30:11 akmodsbuild: CONFTEST: atomic_long_type
2019/11/11 16:30:11 akmodsbuild: CONFTEST: pci_save_state
2019/11/11 16:30:11 akmodsbuild: CONFTEST: file_inode
2019/11/11 16:30:11 akmodsbuild: CONFTEST: task_struct
2019/11/11 16:30:11 akmodsbuild: CONFTEST: kuid_t
2019/11/11 16:30:11 akmodsbuild: CONFTEST: dma_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: swiotlb_dma_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: dma_map_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: noncoherent_swiotlb_dma_ops
2019/11/11 16:30:11 akmodsbuild: CONFTEST: vm_fault_present
2019/11/11 16:30:11 akmodsbuild: CONFTEST: vm_fault_has_address
2019/11/11 16:30:11 akmodsbuild: CONFTEST: kernel_write
2019/11/11 16:30:11 akmodsbuild: CONFTEST: strnstr
2019/11/11 16:30:11 akmodsbuild: CONFTEST: iterate_dir
2019/11/11 16:30:11 akmodsbuild: CONFTEST: kstrtoull
2019/11/11 16:30:11 akmodsbuild: CONFTEST: backlight_properties_type
2019/11/11 16:30:11 akmodsbuild: CONFTEST: fault_flags
2019/11/11 16:30:11 akmodsbuild: CONFTEST: atomic64_type
2019/11/11 16:30:11 akmodsbuild: CONFTEST: address_space
2019/11/11 16:30:11 akmodsbuild: CONFTEST: backing_dev_info
2019/11/11 16:30:11 akmodsbuild: CONFTEST: mm_context_t
2019/11/11 16:30:11 akmodsbuild: CONFTEST: vm_ops_fault_removed_vma_arg
2019/11/11 16:30:11 akmodsbuild: CONFTEST: pnv_npu2_init_context
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_bus_present
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_bus_has_bus_type
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_bus_has_get_irq
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_bus_has_get_name
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_driver_has_legacy_dev_list
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_driver_has_set_busid
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_crtc_state_has_connectors_changed
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_init_function_args
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_helper_mode_fill_fb_struct
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_master_drop_has_from_release_arg
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_driver_unload_has_int_return_type
2019/11/11 16:30:11 akmodsbuild: CONFTEST: kref_has_refcount_of_type_refcount_t
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_mode_object_find_has_file_priv_arg
2019/11/11 16:30:11 akmodsbuild: CONFTEST: dom0_kernel_present
2019/11/11 16:30:11 akmodsbuild: CONFTEST: nvidia_vgpu_kvm_build
2019/11/11 16:30:11 akmodsbuild: CONFTEST: nvidia_grid_build
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_available
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_atomic_available
2019/11/11 16:30:11 akmodsbuild: CONFTEST: drm_atomic_modeset_nonblocking_commit_available
2019/11/11 16:30:11 akmodsbuild: CONFTEST: is_export_symbol_gpl_refcount_inc
2019/11/11 16:30:11 akmodsbuild: CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
2019/11/11 16:30:11 akmodsbuild: cc -Wp,-MD,/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/.nv-frontend.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fvar-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="390.116" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Wno-sign-compare -Wno-format-extra-args -Werror=undef -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME='"nv_frontend"' -DKBUILD_MODNAME='"nvidia"' -c -o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-frontend.o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-frontend.c
2019/11/11 16:30:11 akmodsbuild: cc -Wp,-MD,/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/.nv-instance.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fvar-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="390.116" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Wno-sign-compare -Wno-format-extra-args -Werror=undef -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME='"nv_instance"' -DKBUILD_MODNAME='"nvidia"' -c -o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.c
2019/11/11 16:30:11 akmodsbuild: cc -Wp,-MD,/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/.nv-gpu-numa.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fvar-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="390.116" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Wno-sign-compare -Wno-format-extra-args -Werror=undef -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME='"nv_gpu_numa"' -DKBUILD_MODNAME='"nvidia"' -c -o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-gpu-numa.o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-gpu-numa.c
2019/11/11 16:30:11 akmodsbuild: cc -Wp,-MD,/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fvar-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="390.116" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Wno-sign-compare -Wno-format-extra-args -Werror=undef -I/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME='"nv"' -DKBUILD_MODNAME='"nvidia"' -c -o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv.o /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv.c
2019/11/11 16:30:11 akmodsbuild: In file included from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-linux.h:136,
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-frontend.c:13:
2019/11/11 16:30:11 akmodsbuild: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-list-helpers.h:94:19: error: redefinition of 'list_is_first'
2019/11/11 16:30:11 akmodsbuild: 94 | static inline int list_is_first(const struct list_head *list,
2019/11/11 16:30:11 akmodsbuild: | ^~~~~~~~~~~~~
2019/11/11 16:30:11 akmodsbuild: In file included from ./include/linux/preempt.h:11,
2019/11/11 16:30:11 akmodsbuild: from ./include/linux/spinlock.h:51,
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-lock.h:16,
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/common/inc/nv-linux.h:19,
2019/11/11 16:30:11 akmodsbuild: ./include/linux/list.h:245:19: note: previous definition of 'list_is_first' was here
2019/11/11 16:30:11 akmodsbuild: 245 | static inline int list_is_first(const struct list_head *list,
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-gpu-numa.c:24:
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv.c:13:
2019/11/11 16:30:11 akmodsbuild: from /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.c:13:
2019/11/11 16:30:11 akmodsbuild: make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-gpu-numa.o] Error 1
2019/11/11 16:30:11 akmodsbuild: make[2]: *** Waiting for unfinished jobs....
2019/11/11 16:30:11 akmodsbuild: make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-frontend.o] Error 1
2019/11/11 16:30:11 akmodsbuild: make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv-instance.o] Error 1
2019/11/11 16:30:11 akmodsbuild: make[2]: *** [scripts/Makefile.build:281: /tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64/nvidia/nv.o] Error 1
2019/11/11 16:30:11 akmodsbuild: make[1]: *** [Makefile:1630: _module_/tmp/akmodsbuild.rGFUWFzm/BUILD/nvidia-390xx-kmod-390.116/_kmod_build_5.3.9-200.fc30.x86_64] Error 2
2019/11/11 16:30:11 akmodsbuild: make[1]: Leaving directory '/usr/src/kernels/5.3.9-200.fc30.x86_64'
2019/11/11 16:30:11 akmodsbuild: make: *** [Makefile:79: modules] Error 2
2019/11/11 16:30:11 akmodsbuild: error: Bad exit status from /var/tmp/rpm-tmp.rliDHg (%build)
2019/11/11 16:30:11 akmodsbuild: RPM build errors:
2019/11/11 16:30:11 akmodsbuild: user mockbuild does not exist - using root
2019/11/11 16:30:11 akmodsbuild: group mock does not exist - using root
2019/11/11 16:30:11 akmodsbuild: Bad exit status from /var/tmp/rpm-tmp.rliDHg (%build)
2019/11/11 16:30:11 akmods: Building rpms failed; see /var/cache/akmods/nvidia-390xx/390.116-2-for-5.3.9-200.fc30.x86_64.failed.log for details
