Hello everyone,
i’m currently having a problem implementing an object detection model trained by nvidia digits
and i always get this erros : cv2.error: OpenCV(4.2.0) /io/opencv/modules/dnn/src/dnn.cpp:562: error: (-2:Unspecified error) Can’t create layer “cluster” of type “” in function ‘getLayerInstance’
the python code i’m using :
# import the necessary packages
import numpy as np
import argparse
import cv2
# construct the argument parse and parse the arguments
ap = argparse.ArgumentParser()
ap.add_argument("-i", "--image", required=True,
help="path to input image")
ap.add_argument("-p", "--prototxt", required=True,
help="path to Caffe 'deploy' prototxt file")
ap.add_argument("-m", "--model", required=True,
help="path to Caffe pre-trained model")
ap.add_argument("-c", "--confidence", type=float, default=0.2,
help="minimum probability to filter weak detections")
args = vars(ap.parse_args())
# initialize the list of class labels MobileNet SSD was trained to
# detect, then generate a set of bounding box colors for each class
CLASSES = ["Carrefour"]
COLORS = np.random.uniform(0, 255, size=(len(CLASSES), 3))
# load our serialized model from disk
print("[INFO] loading model...")
net = cv2.dnn.readNetFromCaffe(args["prototxt"], args["model"])
class ClusterDetections(model):
def __init__(self, params, blobs):
self.is_groundtruth = False
try:
plist = params['param_str'].split(',')
self.image_size_x = int(plist[0])
self.image_size_y = int(plist[1])
self.stride = int(plist[2])
self.gridbox_cvg_threshold = float(plist[3])
self.gridbox_rect_thresh = int(plist[4])
self.gridbox_rect_eps = float(plist[5])
self.min_height = int(plist[6])
self.num_classes = int(plist[7]) if len(plist) > 7 else 1
except ValueError:
raise ValueError("Parameter string missing or data type is wrong!")
def getMemoryShapes(self, bottom):
n_images = bottom[0][0]
num_classes = bottom[0][1]
if num_classes != self.num_classes:
raise ValueError("Unexpected number of classes: %d != %d, bottom[0] shape=%s" % (num_classes, self.num_classes, repr(bottom[0].data.shape)))
top = []
for i in xrange(num_classes):
top.append([1, n_images, MAX_BOXES, 5]) # Make it 4-dimensional
return top
def forward(self, bottom):
top = []
for i in xrange(self.num_classes):
data0 = bottom[0][:,i:i+1,:,:]
bbox = cluster(self, data0, bottom[1])
top.append(np.expand_dims(bbox.astype(np.float32), 0))
return top
cv2.dnn_registerLayer('ClusterDetections', ClusterDetections)
# load the input image and construct an input blob for the image
# by resizing to a fixed 300x300 pixels and then normalizing it
# (note: normalization is done via the authors of the MobileNet SSD
# implementation)
image = cv2.imread(args["image"])
(h, w) = image.shape[:2]
blob = cv2.dnn.blobFromImage(cv2.resize(image, (300, 300)), 0.007843, (300, 300), 127.5)
# pass the blob through the network and obtain the detections and
# predictions
print("[INFO] computing object detections...")
net.setInput(blob)
detections = net.forward()
# loop over the detections
for i in np.arange(0, detections.shape[2]):
# extract the confidence (i.e., probability) associated with the
# prediction
confidence = detections[0, 0, i, 2]
# filter out weak detections by ensuring the `confidence` is
# greater than the minimum confidence
if confidence > args["confidence"]:
# extract the index of the class label from the `detections`,
# then compute the (x, y)-coordinates of the bounding box for
# the object
idx = int(detections[0, 0, i, 1])
box = detections[0, 0, i, 3:7] * np.array([w, h, w, h])
(startX, startY, endX, endY) = box.astype("int")
# display the prediction
label = "{}: {:.2f}%".format(CLASSES[idx], confidence * 100)
print("[INFO] {}".format(label))
cv2.rectangle(image, (startX, startY), (endX, endY),
COLORS[idx], 2)
y = startY - 15 if startY - 15 > 15 else startY + 15
cv2.putText(image, label, (startX, y),
cv2.FONT_HERSHEY_SIMPLEX, 0.5, COLORS[idx], 2)
# show the output image
cv2.imshow("Output", image)
cv2.waitKey(0)
deploy.prototxt :
input: "data"
input_shape {
dim: 1
dim: 3
dim: 384
dim: 1248
layer {
type: "Power"
bottom: "data"
top: "transformed_data"
power_param {
shift: -127.0
layer {
type: "Convolution"
bottom: "transformed_data"
top: "conv1/7x7_s2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
value: 0.20000000298
layer {
type: "ReLU"
bottom: "conv1/7x7_s2"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool1/3x3_s2"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 9.99999974738e-05
beta: 0.75
layer {
type: "Convolution"
bottom: "pool1/norm1"
top: "conv2/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "conv2/3x3_reduce"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.0299999993294
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
beta: 0.75
layer {
type: "Pooling"
bottom: "conv2/norm2"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool2/3x3_s2"
top: "inception_3a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/1x1"
layer {
type: "Convolution"
top: "inception_3a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.0900000035763
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/3x3"
layer {
type: "Convolution"
top: "inception_3a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/5x5"
layer {
type: "Pooling"
top: "inception_3a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3a/pool"
top: "inception_3a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/pool_proj"
layer {
type: "Concat"
top: "inception_3a/output"
layer {
type: "Convolution"
bottom: "inception_3a/output"
top: "inception_3b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/1x1"
layer {
type: "Convolution"
top: "inception_3b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/3x3"
layer {
type: "Convolution"
top: "inception_3b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/5x5"
layer {
type: "Pooling"
top: "inception_3b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3b/pool"
top: "inception_3b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/pool_proj"
layer {
type: "Concat"
top: "inception_3b/output"
layer {
type: "Pooling"
bottom: "inception_3b/output"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool3/3x3_s2"
top: "inception_4a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/1x1"
layer {
type: "Convolution"
top: "inception_4a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/3x3"
layer {
type: "Convolution"
top: "inception_4a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/5x5"
layer {
type: "Pooling"
top: "inception_4a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4a/pool"
top: "inception_4a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/pool_proj"
layer {
type: "Concat"
top: "inception_4a/output"
layer {
type: "Convolution"
bottom: "inception_4a/output"
top: "inception_4b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/1x1"
layer {
type: "Convolution"
top: "inception_4b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/3x3"
layer {
type: "Convolution"
top: "inception_4b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/5x5"
layer {
type: "Pooling"
top: "inception_4b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4b/pool"
top: "inception_4b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/pool_proj"
layer {
type: "Concat"
top: "inception_4b/output"
layer {
type: "Convolution"
bottom: "inception_4b/output"
top: "inception_4c/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/1x1"
layer {
type: "Convolution"
top: "inception_4c/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4c/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/3x3"
layer {
type: "Convolution"
top: "inception_4c/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4c/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/5x5"
layer {
type: "Pooling"
top: "inception_4c/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4c/pool"
top: "inception_4c/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/pool_proj"
layer {
type: "Concat"
top: "inception_4c/output"
layer {
type: "Convolution"
bottom: "inception_4c/output"
top: "inception_4d/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/1x1"
layer {
type: "Convolution"
top: "inception_4d/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4d/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/3x3"
layer {
type: "Convolution"
top: "inception_4d/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4d/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/5x5"
layer {
type: "Pooling"
top: "inception_4d/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4d/pool"
top: "inception_4d/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/pool_proj"
layer {
type: "Concat"
top: "inception_4d/output"
layer {
type: "Convolution"
bottom: "inception_4d/output"
top: "inception_4e/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/1x1"
layer {
type: "Convolution"
top: "inception_4e/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4e/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/3x3"
layer {
type: "Convolution"
top: "inception_4e/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4e/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/5x5"
layer {
type: "Pooling"
top: "inception_4e/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4e/pool"
top: "inception_4e/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/pool_proj"
layer {
type: "Concat"
top: "inception_4e/output"
layer {
type: "Convolution"
bottom: "inception_4e/output"
top: "inception_5a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/1x1"
layer {
type: "Convolution"
top: "inception_5a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/3x3"
layer {
type: "Convolution"
top: "inception_5a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/5x5"
layer {
type: "Pooling"
top: "inception_5a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5a/pool"
top: "inception_5a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/pool_proj"
layer {
type: "Concat"
top: "inception_5a/output"
layer {
type: "Convolution"
bottom: "inception_5a/output"
top: "inception_5b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/1x1"
layer {
type: "Convolution"
top: "inception_5b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/3x3"
layer {
type: "Convolution"
top: "inception_5b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/5x5"
layer {
type: "Pooling"
top: "inception_5b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5b/pool"
top: "inception_5b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/pool_proj"
layer {
type: "Concat"
top: "inception_5b/output"
layer {
type: "Dropout"
bottom: "inception_5b/output"
top: "pool5/drop_s1"
dropout_param {
dropout_ratio: 0.40000000596
layer {
type: "Convolution"
bottom: "pool5/drop_s1"
top: "cvg/classifier"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 1
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Sigmoid"
bottom: "cvg/classifier"
top: "coverage"
layer {
type: "Convolution"
top: "bboxes"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: 'ClusterDetections'
bottom: 'coverage'
bottom: 'bboxes'
top: 'bbox-list'
python_param {
param_str: '1248, 352, 16, 0.6, 3, 0.02, 22, 1'
https://answers.opencv.org/question/189822/assertion-error-with-custom-trained-caffe/
applied what this says and still didn’t work unless i didn’t do it correclty if i didn’t can you please tell me what should i do ?
