I have a custom model which I have trained and tested in digits on host successfully. Before downloading the model and transferring on Jetson TX2
At the end of deploy.prototxt, deleted the layer named cluster:
layer {
type: "Python"
bottom: "coverage"
bottom: "bboxes"
top: "bbox-list"
python_param {
module: "caffe.layers.detectnet.clustering"
layer: "ClusterDetections"
param_str: "640, 640, 16, 0.6, 2, 0.02, 22, 1"
Without this Python layer, the snapshot can now be imported into TensorRT onboard the Jetson.
$NET=object_detection_model
$ ./detectnet-console bottle_0.jpg output_0.jpg \
--prototxt=$NET/deploy.prototxt \
--model=$NET/snapshot_iter_33660.caffemodel \
--input_blob=data \
--output_cvg=coverage \
--output_bbox=bboxes
But after set the NET above and running command below this is what I am getting. Just for the Information my object_detection folder is in /home/sp while images and detectnet-console are been loaded from ~/jetson-inference/build/aarch64/bin
./detectnet-console bottle_0.jpg obj_detect.jpg \ --prototxt=$NET/deploy.prototxt \ --model=$NET/snapshot_iter_33660.caffemodel \ --input_blob=data \ --output_cvg=coverage \ --output_bbox=bboxes
detectnet-console
args (8): 0 [./detectnet-console] 1 [bottle_0.jpg] 2 [obj_detect.jpg] 3 [--prototxt=object_detection/deploy.prototxt] 4 [--model=object_detection/snapshot_iter_33660.caffemodel] 5 [--input_blob=data] 6 [ --output_cvg=coverage] 7 [ --output_bbox=bboxes]
detectNet -- loading detection network model from:
-- prototxt object_detection/deploy.prototxt
-- model object_detection/snapshot_iter_33660.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- class_labels NULL
-- threshold 0.500000
-- batch_size 2
[TRT] TensorRT version 5.0.6
[TRT] detected model format - caffe (extension '.caffemodel')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file .2.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading
[TRT] CaffeParser: Could not open file
[TRT] CaffeParser: Could not parse model file
[TRT] device GPU, failed to parse caffe network
device GPU, failed to load
detectNet -- failed to initialize.
detectnet-console: failed to initialize detectNet
well my model detected objects perfectly in digits on host. But not sure what is causing the issue. could anyone please take a look? Thanks. Though I am trying my best to solve this issue will update if anything. I also made sure I am naming all the files correctly in command line command
It looks like the application cannot find the model correctly.
Would you mind to set the $NET with the absolutely path to see if helps first?
After setting $NET=/home/sp/object_detection I got this. But I am able to run sample object detection and image detection models which are been pretrained in jetson-inference tutorial.
But I am trying to figure out and solve this issue it would be great if you help @AastaLLL. Thanks and cheers
./detectnet-console bottle_0.jpg obj_detect.jpg --prototxt=$NET/deploy.prototxt --model=$NET/snapshot_iter_33660.caffemodel --input_blob=data \ --output_cvg=coverage \ --output_bbox=bboxes
detectnet-console
args (8): 0 [./detectnet-console] 1 [bottle_0.jpg] 2 [obj_detect.jpg] 3 [--prototxt=/home/sp/object_detection/deploy.prototxt] 4 [--model=/home/sp/object_detection/snapshot_iter_33660.caffemodel] 5 [--input_blob=data] 6 [ --output_cvg=coverage] 7 [ --output_bbox=bboxes]
-- prototxt /home/sp/object_detection/deploy.prototxt
-- model /home/sp/object_detection/snapshot_iter_33660.caffemodel
-- batch_size 2
[TRT] attempting to open engine cache file /home/sp/object_detection/snapshot_iter_33660.caffemodel.2.1.GPU.FP16.engine
[TRT] device GPU, loading /home/sp/object_detection/deploy.prototxt /home/sp/object_detection/snapshot_iter_33660.caffemodel
[libprotobuf ERROR google/protobuf/text_format.cc:298] Error parsing text-format ditcaffe.NetParameter: 2173:1: Expected identifier, got: }
[TRT] CaffeParser: Could not parse deploy file
device GPU, failed to load /home/sp/object_detection/snapshot_iter_33660.caffemodel
Based on your log:
It looks like your prototxt file may not follow the format correctly.
Would you mind to double check if the representation is valid after removing the python layer.
If everything looks good, would you mind to share your prototxt with us for debugging?
layer {
type: "Python"
bottom: "coverage"
bottom: "bboxes"
top: "bbox-list"
python_param {
I removed the above layer as per dusty-nv object detection tutorial from my deploy.prototxt. Thank you very much for replying and please let me know if you require more information. Thanks again really appreciate it
input: "data"
input_shape {
dim: 1
dim: 3
dim: 640
dim: 640
layer {
type: "Power"
bottom: "data"
top: "transformed_data"
power_param {
shift: -127.0
layer {
type: "Convolution"
bottom: "transformed_data"
top: "conv1/7x7_s2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
value: 0.20000000298
layer {
type: "ReLU"
bottom: "conv1/7x7_s2"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool1/3x3_s2"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 9.99999974738e-05
beta: 0.75
layer {
type: "Convolution"
bottom: "pool1/norm1"
top: "conv2/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "conv2/3x3_reduce"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.0299999993294
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
beta: 0.75
layer {
type: "Pooling"
bottom: "conv2/norm2"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool2/3x3_s2"
top: "inception_3a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/1x1"
layer {
type: "Convolution"
top: "inception_3a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.0900000035763
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/3x3"
layer {
type: "Convolution"
top: "inception_3a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/5x5"
layer {
type: "Pooling"
top: "inception_3a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3a/pool"
top: "inception_3a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3a/pool_proj"
layer {
type: "Concat"
top: "inception_3a/output"
layer {
type: "Convolution"
bottom: "inception_3a/output"
top: "inception_3b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/1x1"
layer {
type: "Convolution"
top: "inception_3b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/3x3"
layer {
type: "Convolution"
top: "inception_3b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/5x5"
layer {
type: "Pooling"
top: "inception_3b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3b/pool"
top: "inception_3b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_3b/pool_proj"
layer {
type: "Concat"
top: "inception_3b/output"
layer {
type: "Pooling"
bottom: "inception_3b/output"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool3/3x3_s2"
top: "inception_4a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/1x1"
layer {
type: "Convolution"
top: "inception_4a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/3x3"
layer {
type: "Convolution"
top: "inception_4a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/5x5"
layer {
type: "Pooling"
top: "inception_4a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4a/pool"
top: "inception_4a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4a/pool_proj"
layer {
type: "Concat"
top: "inception_4a/output"
layer {
type: "Convolution"
bottom: "inception_4a/output"
top: "inception_4b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/1x1"
layer {
type: "Convolution"
top: "inception_4b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/3x3"
layer {
type: "Convolution"
top: "inception_4b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/5x5"
layer {
type: "Pooling"
top: "inception_4b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4b/pool"
top: "inception_4b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4b/pool_proj"
layer {
type: "Concat"
top: "inception_4b/output"
layer {
type: "Convolution"
bottom: "inception_4b/output"
top: "inception_4c/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/1x1"
layer {
type: "Convolution"
top: "inception_4c/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4c/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/3x3"
layer {
type: "Convolution"
top: "inception_4c/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4c/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/5x5"
layer {
type: "Pooling"
top: "inception_4c/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4c/pool"
top: "inception_4c/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4c/pool_proj"
layer {
type: "Concat"
top: "inception_4c/output"
layer {
type: "Convolution"
bottom: "inception_4c/output"
top: "inception_4d/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/1x1"
layer {
type: "Convolution"
top: "inception_4d/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4d/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/3x3"
layer {
type: "Convolution"
top: "inception_4d/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4d/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/5x5"
layer {
type: "Pooling"
top: "inception_4d/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4d/pool"
top: "inception_4d/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4d/pool_proj"
layer {
type: "Concat"
top: "inception_4d/output"
layer {
type: "Convolution"
bottom: "inception_4d/output"
top: "inception_4e/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/1x1"
layer {
type: "Convolution"
top: "inception_4e/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4e/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/3x3"
layer {
type: "Convolution"
top: "inception_4e/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4e/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/5x5"
layer {
type: "Pooling"
top: "inception_4e/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4e/pool"
top: "inception_4e/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_4e/pool_proj"
layer {
type: "Concat"
top: "inception_4e/output"
layer {
type: "Convolution"
bottom: "inception_4e/output"
top: "inception_5a/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/1x1"
layer {
type: "Convolution"
top: "inception_5a/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5a/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/3x3"
layer {
type: "Convolution"
top: "inception_5a/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.20000000298
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5a/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/5x5"
layer {
type: "Pooling"
top: "inception_5a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5a/pool"
top: "inception_5a/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5a/pool_proj"
layer {
type: "Concat"
top: "inception_5a/output"
layer {
type: "Convolution"
bottom: "inception_5a/output"
top: "inception_5b/1x1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/1x1"
layer {
type: "Convolution"
top: "inception_5b/3x3_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5b/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/3x3"
layer {
type: "Convolution"
top: "inception_5b/5x5_reduce"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5b/5x5"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/5x5"
layer {
type: "Pooling"
top: "inception_5b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5b/pool"
top: "inception_5b/pool_proj"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.10000000149
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "inception_5b/pool_proj"
layer {
type: "Concat"
top: "inception_5b/output"
layer {
type: "Dropout"
bottom: "inception_5b/output"
top: "pool5/drop_s1"
dropout_param {
dropout_ratio: 0.40000000596
layer {
type: "Convolution"
bottom: "pool5/drop_s1"
top: "cvg/classifier"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 1
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Sigmoid"
bottom: "cvg/classifier"
top: "coverage"
layer {
type: "Convolution"
top: "bboxes"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
We have checked your .prototxt file with trtexec and it can be parsed without issues.
nvidia@nvidia-desktop:~/tensorrt/bin$ ./trtexec --deploy=./test.prototxt --output=bboxes --output=coverage
&&&& RUNNING TensorRT.trtexec # ./trtexec --deploy=./test.prototxt --output=bboxes --output=coverage
[I] deploy: ./test.prototxt
[I] output: bboxes
[I] output: coverage
[I] Input "data": 3x640x640
[I] Output "bboxes": 4x40x40
[I] Output "coverage": 1x40x40
[I] Average over 10 runs is 167.178 ms (host walltime is 168.847 ms, 99% percentile time is 170.759).
[I] Average over 10 runs is 167.167 ms (host walltime is 168.606 ms, 99% percentile time is 171.13).
[I] Average over 10 runs is 167.644 ms (host walltime is 168.906 ms, 99% percentile time is 170.785).
[I] Average over 10 runs is 167.944 ms (host walltime is 168.883 ms, 99% percentile time is 170.796).
[I] Average over 10 runs is 167.761 ms (host walltime is 168.852 ms, 99% percentile time is 170.462).
[I] Average over 10 runs is 168.012 ms (host walltime is 168.894 ms, 99% percentile time is 171.395).
[I] Average over 10 runs is 168.109 ms (host walltime is 169.165 ms, 99% percentile time is 174.659).
[I] Average over 10 runs is 168.066 ms (host walltime is 169.404 ms, 99% percentile time is 171.171).
[I] Average over 10 runs is 167.782 ms (host walltime is 168.886 ms, 99% percentile time is 171.059).
[I] Average over 10 runs is 167.578 ms (host walltime is 168.77 ms, 99% percentile time is 170.891).
&&&& PASSED TensorRT.trtexec # ./trtexec --deploy=./test.prototxt --output=bboxes --output=coverage
May I know which JetPack version do you use?
If not v4.2.1 or above, could you give it a try?
I was using jetpack 4.0 before but after your suggestion I installed jetpack v4.2.1 and it worked thanks
