Background:
Windows 7
lenovo w540 (intel & Quadro k2100m)
Cuda 10 (had same problem with 9, jumped over to Cuda 10)
Driver 412.16 (tried several versions)
So, If I build a sample program, it compiles and build fine, but when trying to run it, I get a message:
‘Frame not in Module’
Get an exception:
Exception thrown at 0x000000007712759E (ntdll.dll) in sample01.exe: 0xC0000005: Access violation writing location 0x0000000000000000.
Thought about exactly this. -g (host) was enabled already, but -G (device) was not. Sadly, when I enable -G, Nsight no longer breaks on the OutOfRangeLoad exceptions. Problem solved, right ?
Would you happen to have any thoughts on what the issue might be ?
If debugging a GPU Kernel, NsightVSE Legacy Debugger can help
** Try using -lineinfo (instead of -G)
** You might have better luck
*** putting the driver in TCC mode
*** using the Nsight Next-Gen Debugger (which does CPU and GPU debugging), but that would require a Pascal or later GPU.
