My computer is Legion Pro 7 16IAX10H and I am running CachyOS Linux 7.0.12-1-cachyos. NVIDIA driver version is 610.43.02.
My computer has three video outputs: 1 HDMI, 2 USB-C DisplayPort. One of the DisplayPort is wired to Intel, the HDMI and other USB-C are NVIDIA.
I have Samsung G50SF monitor. Actually I have three of them but the same problem also happens with one. When I try to enable HDR on the monitor plugged in to NVIDIA USB-C DisplayPort, I loose video signal from NVIDIA GPU, and I get these errors. The monitor say no signal and turns off. The other monitor on NVIDIA HDMI comes back on with a frozen image. Only Intel video works. I can unplug monitors from NVIDIA but if I plug them back in they still don’t work. And I cannot shut down, the OS freezes once I try to shut down, so I have to power off.
On HDMI and on Intel USB-C I can enable HDR with no problem. But this one USB-C port wired to NVIDIA, I can’t turn on HDR.
Here is output from journalctl --user-unit plasma-kwin_wayland --boot 0
Jun 18 20:21:04 cachyos systemd[1430]: Starting KDE Wayland Compositor...
Jun 18 20:21:04 cachyos systemd[1430]: Started KDE Wayland Compositor.
Jun 18 20:21:04 cachyos kwin_wayland[1553]: No backend specified, automatically choosing drm
Jun 18 20:21:04 cachyos kwin_wayland[1553]: Libinput: event16 - GAOMON Gaomon Tablet: libinput bug: missing tablet capabilities: xy pen btn-stylus resolution. Ignoring this device.
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: > Warning: Multiple symbols for level 1/group 1 on key <FK23>
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: > Using F23, ignoring XF86TouchpadOff
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: > Warning: Symbol map for key <FK23> redefined
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: > Using last definition for conflicting fields
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: > Warning: Symbol map for key <FK24> redefined
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1638]: Errors from xkbcomp are not fatal to the X server
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: > Warning: Unsupported maximum keycode 709, clipping.
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: > X11 cannot support keycodes above 255.
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: > Warning: Virtual modifier Hyper multiply defined
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: > Using 0, ignoring 0
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: > Warning: Virtual modifier ScrollLock multiply defined
Jun 18 20:21:05 cachyos kwin_wayland_wrapper[1649]: Errors from xkbcomp are not fatal to the X server
Jun 18 20:22:20 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:20 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:20 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:21 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:21 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:21 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:22 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:22 cachyos kwin_wayland[1553]: Please report this at
Jun 18 20:22:22 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:23 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:23 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:23 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:24 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:24 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:24 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:25 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:25 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:25 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:26 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:26 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:26 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:27 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:27 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:27 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:28 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:28 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:28 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:29 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:29 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:29 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:30 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:30 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:30 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:31 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:31 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:31 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:32 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:32 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:32 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:33 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:33 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:33 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:34 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:34 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:34 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:35 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:35 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:35 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:36 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:36 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:36 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:37 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:37 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:37 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:38 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:38 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:38 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:39 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:39 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:39 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:40 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:40 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:40 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:41 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:41 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:41 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:42 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:42 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:42 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:43 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:43 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:43 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:44 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:44 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:44 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:45 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:45 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:45 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:46 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:46 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:46 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:47 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:47 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:47 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:48 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:48 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:48 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:49 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:49 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:49 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:50 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:50 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:50 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:51 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:51 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:51 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:52 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:52 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:52 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:53 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:53 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:53 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:54 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:54 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:54 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:55 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:55 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:55 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:56 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:56 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:56 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:57 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:57 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:57 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:58 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:58 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:58 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:22:59 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:22:59 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:22:59 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:00 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:00 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:00 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:01 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:01 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:01 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:02 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:02 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:02 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:03 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:03 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:03 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:04 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:04 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:04 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:05 cachyos kwin_wayland[1553]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Jun 18 20:23:05 cachyos kwin_wayland[1553]: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Jun 18 20:23:05 cachyos kwin_wayland[1553]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Jun 18 20:23:05 cachyos kwin_wayland[1553]: EDID colorimetry xy(0.330078, 0.297852) xy(0.597656, 0.149414) xy(0.0605469, 0.314453) xy(0.328125, 0.00292969) is invalid
And here is dmesg
dmesg.txt (100.1 KB)
