I have the following pipeline:
streammux > pgie > nvtracker > nvdsanalytics > nvvidconverter > tiler > nvosd > nveglglessink
I want to add the nvof plugin to use the optical flow data.
when I add the nvof plugin right after the pgie while keeping everything else as is, I get a segmentation fault error when I try to extract the nvof meta data. It only works if I remove the nvdsanalytics plugin from the pipeline.
GPU
• DeepStream Version
5.1
• TensorRT Version
7.2.2
465.19.01
bugs
