- Hardware Platform (Jetson / GPU) - N/A
- DeepStream Version - v5.1.0
- JetPack Version (valid for Jetson only) - N/A
- TensorRT Version - N/A
- Issue Type (questions, new requirements, bugs) - New requirement
As of version v5.1.0 of Deepstream as available on the nvcr, the nvof plugin reports that it is still using version 1.0.10 of the Optical Flow SDK library.
Factory Details:
Rank primary (256)
Long-name nvof
Klass nvof
Description Gstreamer NV Optical Flow Plugin
Author NVIDIA Corporation. Post on Deepstream for Jetson/Tesla forum for any queries @ https://devtalk.nvidia.com/default/board/209/
Plugin Details:
Name nvdsgst_of
Description NVIDIA opticalflow plugin for integration with DeepStream on DGPU
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so
Version 4.0
License Proprietary
Source module nvopticalflow
Binary package NVIDIA DeepStream 3rdparty IP integration opticalflow plugin
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseTransform
+----GstNvOpticalFlow
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { (string)NV12 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
SRC template: 'src'
Capabilities:
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvopticalflow0"
parent : The parent of the object
Object of type "GstObject"
qos : Handle Quality-of-Service events
Boolean. Default: false
gpu-id : Set GPU Device ID
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 4294967295 Default: 0
dump-of-meta : Dump Optical Flow Meta
preset-level : Type of Preset Levels
Enum "GstNvOFPresetLevel" Default: 0, "NV_OF_PERF_LEVEL_FAST"
(0): NV_OF_PERF_LEVEL_FAST - High performance and low quality
(1): NV_OF_PERF_LEVEL_MEDIUM - Low performance and medium quality
(2): NV_OF_PERF_LEVEL_SLOW - Lowest performance and best quality
grid-size : Type of Grid Size
Enum "GstNvOFGridSize" Default: 0, "NVOF_GRID_SIZE_4x4"
(0): NVOF_GRID_SIZE_4x4 - Optical Flow Grid Size 4x4
pool-size : Size of optical flow memory pool
Unsigned Integer. Range: 1 - 4294967295 Default: 7
nvof-lib-version : Optical Flow Library Version
flags: readable
String. Default: "1.0.10"
Yet, as of current, we are already up to version 3.0 of the Optical Flow SDK.
This is proving to be a bit of an issue for us, as it means that we are not able to receive the benefits of any fixes, improvements and new features that newer versions of the Optical Flow SDK library can give us.
Do you have any roadmap on when the Optical Flow SDK version that the nvof Deepstream plugin will be updated to the latest version, so that users of Deepstream can take advantage of the benefits of the latest Optical Flow SDK version?
