After running deepstream-test3-app, get such warnings
(gst-plugin-scanner:13760): GStreamer-WARNING **: 12:40:06.306: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:13760): GStreamer-WARNING **: 12:40:06.462: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so': libucs.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:13760): GStreamer-WARNING **: 12:40:06.474: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvmultiurisrcbin.so': libjsoncpp.so.25: cannot open shared object file: No such file or directory
(gst-plugin-scanner:13760): GStreamer-WARNING **: 12:40:06.480: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine open error
0:00:05.245368589 13759 0x55dcb4a8c890 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine failed
0:00:05.302921144 13759 0x55dcb4a8c890 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine failed, try rebuild
• DeepStream Version
• TensorRT Version
• The pipeline being used
| NVIDIA-SMI 535.154.05 Driver Version: 535.154.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1660 ... On | 00000000:01:00.0 On | N/A |
| 40% 32C P8 8W / 125W | 221MiB / 6144MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1035 G /usr/lib/xorg/Xorg 122MiB |
| 0 N/A N/A 1343 G /usr/bin/gnome-shell 96MiB |
DeepStream Version: 6.4 on Ubuntu 22.04
cudnn:8.9.4 TensorRT:8.6.1
yingliu
January 20, 2024, 11:40am
5
Can you try “sudo ldconfig” and execute your command again?
Hence we are closing this topic. If need further support, please open a new one. Thanks
You don’t have the correct installation dependencies
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#id1
Please ignore these two warnings, which are for the DPU network card. If there is no related hardware, they will appear. They will only appear when the DS program runs for the first time and will not affect the program
system
Closed
February 6, 2024, 11:25am
7
