DS 7.0
dGPU, Triton docker
I’m running the 7.0-triton-multiarch docker. So far it works fine. I initially noticed a very bad video quality on the RTSP output side, until I noticed these warnings:
(main:7560): GStreamer-WARNING **: 06:49:05.183: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(main:7560): GStreamer-WARNING **: 06:49:05.184: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.1: cannot open shared object file: No such file or directory
(main:7560): GStreamer-WARNING **: 06:49:05.190: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(main:7560): GStreamer-WARNING **: 06:49:05.190: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(main:7560): GStreamer-WARNING **: 06:49:05.190: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(main:7560): GStreamer-WARNING **: 06:49:05.191: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
(main:7560): GStreamer-WARNING **: 06:49:05.192: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
Some research brought up the solution to run ./user_additional_install.sh in /opt/nvidia/deepstream/deepstream-7.0 (Unable to create Streammux - #7 by Ni_Fury)
This dramatically helped, but two warnings (actually one) persists:
(main:18116): GStreamer-WARNING **: 06:56:01.189: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(main:18116): GStreamer-WARNING **: 06:56:01.775: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.1: cannot open shared object file: No such file or directory
There is indeed no such a file libdrivermax.so.1 in the entire image, but the problem doesn’t harm either. Any suggestions to get rid of this warning too?
