• Hardware Platform (Jetson / GPU) --GPU
• DeepStream Version–6.4
• TensorRT Version
/test_samples/yolov8_triton_deepstream_client/test_yolov8_redis_msg.py:244: PyGIDeprecationWarning: Since version 3.11, calling threads_init is no longer needed. See: Projects/PyGObject/Threading - GNOME Wiki!
GObject.threads_init()
0:00:00.012424891 3237 0x563caa12db80 ERROR GST_PLUGIN_LOADING gstpluginloader.c:442:gst_plugin_loader_try_helper: Spawning gst-plugin-scanner helper failed: Failed to close file descriptor for child process (Operation not permitted)
(python3:3237): GStreamer-WARNING **: 07:31:24.362: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
0:00:00.012930071 3237 0x563caa12db80 WARN GST_PLUGIN_LOADING gstplugin.c:875:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.1: cannot open shared object file: No such file or directory
(python3:3237): GStreamer-WARNING **: 07:31:24.362: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
Creating Pipeline
Creating Source
