It is something wrong with running deepstream example
JP : cat /etc/nv_tegra_release
R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t186ref, EABI: aarch64, DATE: Sat Feb 19 17:07:00 UTC 2022
deepstream-app -c ../samples/configs/deepstream-app/source1_csi_dec_infer_resnet_int8.txt
(deepstream-app:9363): GStreamer-WARNING **: 15:54:36.658: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
gst_rtp_onvif_parse_class_init !!!
gst_fake_sink_class_init >>>
** ERROR: <create_multi_source_bin:1424>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1517>: create_multi_source_bin failed
** ERROR: <create_pipeline:1326>: create_pipeline failed
** ERROR: main:688: Failed to create pipeline
Quitting
App run failed
What am I supposed to do?
Thank you.
Moving to DeepStrem SDK fourm for beter support.
• DeepStream Version
• TensorRT Version
Can you find plugin nvstreammux?
gst-inspect-1.0 nvstreammux
Hello, @Amycao
deb package failed.
I downloaded the tar and installed it successfully.
The next issue is a little more urgent, but has nothing been done yet?
Thank you.
Hello @forumuser As the initial issue is solved, please allow me to close this topic, please open a new topic for further questions, thanks.
