GStreamer Failed to load plugin Error
**• Hardware Platform Jetson **
• DeepStream Version 6.0.1
• JetPack Version 4.6.1
• TensorRT Version 8.2
Running the deepstream-app --version-all command gave me the below details:
(gst-plugin-scanner:11836): GStreamer-WARNING **: 11:36:05.458: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:11836): GStreamer-WARNING **: 11:36:06.056: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 8.2
cuDNN Version: 8.2
libNVWarp360 Version: 2.0.1d3
How do I resolve the GStreamer Plugin Warning, Is it something that I can overlook?
PS- Running the same command (deepstream-app --version-all) for the second/third time did not give me the above GStreamer plugin warning.
Your can ignore that warning.
That is for triton and network device.
Okay, thank you.
