• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0
• TensorRT Version 8.01
There are some warnings and erros when I run deepstream-app on ubuntu18.04.
I run deepstream-app on host system.
$ deepstream-app -c ds_app_config.txt
(gst-plugin-scanner:290608): GStreamer-WARNING **: 06:33:03.967: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:290608): GStreamer-WARNING **: 06:33:03.967: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:290608): GStreamer-WARNING **: 06:33:03.973: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
** INFO: <create_udpsink_bin:585>: cap_str_buf is video/x-raw(memory:NVMM), format=I420, width=1920, height=1080
** ERROR: <create_udpsink_bin:688>: create_udpsink_bin failed
** ERROR: <create_sink_bin:1150>: create_sink_bin failed
** ERROR: <create_processing_instance:822>: create_processing_instance failed
** ERROR: <create_pipeline:1397>: create_pipeline failed
** ERROR: <main:660>: Failed to create pipeline
Quitting
App run failed
I have already install deepstream-6.0 according to the web Quickstart Guide — DeepStream 6.0 Release documentation.
I can find udpsink plugin when I use gst-inspect-1.0
$ gst-inspect-1.0 udpsink
Factory Details:
Rank none (0)
Long-name UDP packet sender
Klass Sink/Network
Description Send data over the network via UDP
Author Wim Taymans <wim@fluendo.com>
Please give me a hint.
