Error running deepstream-app
I try to install and run deepstream-app. I followed this:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html
I run JP 5.1.2 and all seems to install fine but deepstream-app complaints about
deepstream-app: error while loading shared libraries: libyaml-cpp.so.0.7: cannot open shared object file: No such file or directory
I have tried building from source and install using apt, but apt does not recognize the library.
Any ideas?
• DeepStream Version
• TensorRT Version
• The pipeline being used
Jetson AGX Orin 64
deepstream_sdk_v6.4.0_jetson.tbz2
JP 5.1.2
• TensorRT Version
ibnvinfer-bin 8.5.2-1+cuda11.4 arm64 TensorRT binaries
I dont know where to find that. Preinstalled from supplier, silicon highway
I get the error as above. I want to run deepstream-app and also deepstream in python. deepstream-app: error while loading shared libraries: libyaml-cpp.so.0.7: cannot open shared object file: No such file or directory
I dont know. I follow the installation instructions from your website for deepstream SDK and it does not work.
No pipline, just trying to run deepstream-app without arguments.
Trying to run python sample app I get errors to.(good that you updated pyds to be installed with pip)
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_1080p_h264.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create NvStreamMux
Unable to create pgie
Unable to create nvvidconv
Unable to create nvosd
Creating nv3dsink
Playing file /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_1080p_h264.h264
None
File ā€œdeepstream_test_1.pyā€, line 259, in
sys.exit(main(sys.argv))
File ā€œdeepstream_test_1.pyā€, line 197, in main
streammux.set_property(ā€˜width’, 1920)
AttributeError: ā€˜NoneType’ object has no attribute 'set_property
I am reinstalling a third system to work with python deepstream. You are more than welcome to give me an official guide and I will let you know where it fails.
I have now a newly flashed Jetson AGX Orin 64 devkit using SDK Manager and have:
Ubuntu 20.04
Jetpack 5.1.2
Deepstream 6.3 (installed from SDK Manager)
I run deepstream-app and I get dependency missing. How do I proceed?
I give you the opportunity to give me a strep by step guide to follow. What I understand
is that deepstream should be installed and ready to be used. But that is not the case.
Ubuntu 20.04
Jetpack 5.1.2
  1. I follow this guide:
    Quickstart Guide — DeepStream documentation 6.4 documentation
    It says to install the dependencies : libssl3. That does not exist!
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package libssl3
I got the deepstream-app to work by installing these missing dependencies and compiling the source:
libgstrtspserver-1.0-0
libjansson4
The rest of the dependencies already exists, so they must come with SDK Manager, but why those two are not included beats me??? Please explain?
I get this warning running:
sudo ./deepstream-test1-app dstest1_config.yml
WARNING: [TRT]: Unknown embedded device detected. Using 59660MiB as the allocation cap for memory on embedded devices.
But after building the engine file it runs inference on the h264 file.
For the first setup I made and got it working I have never gotten ridden of the warnings and why it cant reuse the engine file. I have chmoded the location where I store the engine file since the deepstream-6.3 location is not accessable for the user.
WARNING: Deserialize engine failed because file path: /mnt/M2Disk/resnet10/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:03.304068093 10172 0xaaaaf0c21780 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/mnt/M2Disk/resnet10/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.480228165 10172 0xaaaaf0c21780 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/mnt/M2Disk/resnet10/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.480277925 10172 0xaaaaf0c21780 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
The document you refer to is for DS-6.4, but you installed DS-6.3.DS-6.4 requires ubuntu 22.04, so some library versions are different.
Because they are not part of deepstream, they belong to the open source community. In addition, some libraries are GPL
You need to check if the directory is readable. Or execute chmod -R 777 /opt/nvidia/deepsteam/deepstream
