Hi, I wanted to run deepstream but i get this error. Furthermore, I downloaded the libyml-cpp.so.0.6 and put it in lib dir in deepstream directory but it didn’t work
thanks for your time in advance.
ps. cuda version is 10.2
I think only Jetpack 5 up works with Deepstream 6.1 to use Jetpack 4 downgrade to 6.0 this is from the docs
“Download NVIDIA SDK Manager from JetPack SDK | NVIDIA Developer. You will use this to install JetPack 5.0.1 DP (corresponding to L4T 34.1.1 release)”
