Using Jetpack 4.5.1 and DeepStream 6.01 on Jetson Xavier NX. Attempting to run deepstream-app and get the subject error, notice the lib 8. Suspect that TensorRT incompatibility.
Any help gratefully received.
Cheers
Iain
Cheers
Iain
You should use Deepstream 5.1 for Jetpack 4.5.1
You can use Deepstream 6.0 for Jetpack 4.6
That did the trick, thank you.
