Deepstream-app: error while loading shared libraries: libyaml-cpp.so.0.6: cannot open shared object file: No such file or directory
I successfully upgraded Jetpack to 5.0.2 on Jetson, now after installing deepstream it shows like this:
deepstream-app: error while loading shared libraries: libyaml-cpp.so.0.6: cannot open shared object file: No such file or directory
I tried fixing all packages but it’s still not working.
You should install some dependencies. You can refer to the link below:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#jetson-setup
I did and the error still persists.
How do you install the DeepStream and which version do you install? Could you refer to the link below and check whether it’s a same problem.
https://forums.developer.nvidia.com/t/deepstream-app-error-while-loading-shared-libraries-libyaml-cpp-so-0-6-cannot-open-shared-object-file-no-such-file-or-directory/234799
