• Hardware Platform ( GPU):GPU
**• deepstream-app version 7.0.0
DeepStreamSDK 7.0.0
CUDA Driver Version: 12.1
CUDA Runtime Version: 12.2
TensorRT Version: 8.6
cuDNN Version: 8.9
libNVWarp360 Version: 2.0.1d3
**• Issue Type: bugs
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):
(python3:196): GStreamer-WARNING **: 01:51:05.990: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(python3:196): GStreamer-WARNING **: 01:51:05.993: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
Creating Pipeline
Creating streamux
^C^C^C^C
the program is stucked there, it won’t quit even when I press ctrl+C
Thanks, after sudo /opt/nvidia/deepstream/deepstream/install.sh, it worked just 1 time, then got stucked again.
detail log :
root@vas-desktop:/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out# GST_DEBUG=4 python3 deepstream_test1_rtsp_in_rtsp_out.py -i rtsp://admin:XXXX@192.168.102.200:554/Streaming/Channels/101
0:00:00.000037058 340 0x55b2015698b0 INFO GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.000059749 340 0x55b2015698b0 INFO GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000066809 340 0x55b2015698b0 INFO GST_INIT gst.c:611:init_pre: Linux vas-desktop 5.15.0-69-generic #76~20.04.1-Ubuntu SMP Mon Mar 20 15:54:19 UTC 2023 x86_64
0:00:00.000216514 340 0x55b2015698b0 INFO GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.000357351 340 0x55b2015698b0 INFO GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.000502398 340 0x55b2015698b0 INFO GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000563375 340 0x55b2015698b0 INFO GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.000574679 340 0x55b2015698b0 INFO GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.000594893 340 0x55b2015698b0 INFO GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.008193060 340 0x55b2015698b0 INFO GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.007585 seconds
0:00:00.008234193 340 0x55b2015698b0 INFO GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.010637228 340 0x55b2015698b0 ERROR GST_PLUGIN_LOADING gstpluginloader.c:442:gst_plugin_loader_try_helper: Spawning gst-plugin-scanner helper failed: Failed to close file descriptor for child process (Operation not permitted)
0:00:00.010652686 340 0x55b2015698b0 INFO GST_PLUGIN_LOADING gstpluginloader.c:617:gst_plugin_loader_spawn: No gst-plugin-scanner available, or not working
(python3:340): GStreamer-WARNING **: 10:34:39.240: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
0:00:00.013073495 340 0x55b2015698b0 WARN GST_PLUGIN_LOADING gstplugin.c:875:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.1: cannot open shared object file: No such file or directory
(python3:340): GStreamer-WARNING **: 10:34:39.243: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
0:00:00.013454007 340 0x55b2015698b0 INFO GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.013462899 340 0x55b2015698b0 INFO GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.013478202 340 0x55b2015698b0 INFO GST_INIT gst.c:833:init_post: GLib runtime version: 2.76.6
0:00:00.013482924 340 0x55b2015698b0 INFO GST_INIT gst.c:835:init_post: GLib headers version: 2.72.1
0:00:00.013486362 340 0x55b2015698b0 INFO GST_INIT gst.c:837:init_post: initialized GStreamer successfully
Creating Pipeline
Creating streamux
0:00:00.016627119 340 0x55b2015698b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so” loaded
0:00:00.016741016 340 0x55b2015698b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element “nvstreammux”
0:00:00.016770648 340 0x55b2015698b0 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:GstNvStreamMux@0x55b2018ba530 adding pad ‘src’
