Cant import plugins.cpp file
Hello.How can i import plugins.cpp file on jetson nano ?I cant import this file, because jetson nano just doesnt see this file format.
On this screenshot i am trying to import it in the docker container from my working directory, but i couldnt import it in the main env too.
(docker/run.sh --volume /my/host/path:/my/container/path (/my/host/path is atlas/desktop/Jupiter1)
@A98 did you run python3 setup.py install --plugins when you installed trt_pose inside the container? See this link:
https://github.com/NVIDIA-AI-IOT/trt_pose#step-1—install-dependencies
You should clone/install this inside the running container, as opposed to copying it from the outside.
No,i didnt.Thanks for the reply.
