Can't install h5py nor libhdf5-dev
Hi all,
I am new to working on this and I am trying to get a docker build to work. Here is what I believe are the relevant parts of the dockerfile.
FROM nvcr.io/nvidia/l4t-tensorrt:r8.4.1.5-devel
ARG HOME=/app
ENV DEBIAN_FRONTEND noninteractive
RUN apt-get update && \
    apt-get install --no-install-recommends -y tcl build-essential gcc ffmpeg libsm6 libxext6 python3-dev && \
    apt-get clean && rm -rf /var/lib/apt/lists/*
#Makefile occurs here
RUN /usr/local/bin/pip3 install --no-cache-dir -r req.txt
In my req.txt I have tensorflow==2.13.1. This is resulting in this error:
#0 43.45 error: Unable to load dependency HDF5, make sure HDF5 is installed properly #0 43.45 Library dirs checked: [] #0 43.45 error: libhdf5.so: cannot open shared object file: No such file or directory #0 43.45 [end of output]
Everything I have looked up online indicates that this is missing libhdf5. I have tried adding libhdf5-dev and libhdf5-serial-dev to my apt-get install and they all end up with this error:
0 11.42 Err:13 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libjpeg-turbo8-dev arm64 2.0.3-0ubuntu1.20.04.1
#0 11.42   404  Not Found [IP: 185.125.190.39 80]
#0 11.43 Fetched 6468 kB in 3s (2379 kB/s)
#0 11.43 E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/libj/libjpeg-turbo/libjpeg-turbo8-dev_2.0.3-0ubuntu1.20.04.1_arm64.deb  404  Not Found [IP: 185.125.190.39 80]
#0 11.43 E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is this a problem that I am using the wrong tensorrt version?
Which JetPack do you use?
The container you used is for the JetPack 5.0.2 environment.
How do I find that? I tried
sudo apt-cache show nvidia-jetpack
And got “Unable to locate package nvidia-jetpack no packages found”
Please check this with cat /etc/nv_tegra_release.
For JetPack 5.0.2, the BSP version is r35.1.
It is R35. So that means that I should be using FROM “nvcr.io/nvidia/l4t-tensorrt:r8.4.1.5-devel”? That is the one I have been
I have the build working with “FROM nvcr.io/nvidia/l4t-tensorrt:r8.4.1.5-devel”. I am now trying to start it with “up” and I get this error (I believe this has the relevant parts). Any ideas?:
app | [08/18/2024-20:17:07] [TRT] [E] 6: The engine plan file is not compatible with this version of TensorRT, expecting library version 8.4.1.5 got 8.4.2.4, please rebuild.
app | [08/18/2024-20:17:07] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::49] Error Code 4: Internal Error (Engine deserialization failed.)
The error indicates the TensorRT engine is serialized with a different version.
Please convert the model with the current TensorRT (v8.4) again.
