Jetpack 5.1.1 sudo apt-get install libhdf5-dev fail
nvidia@nvidia:~/Desktop/tensorrt/samples/python/efficientnet$ sudo apt-get install libhdf5-dev
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
libhdf5-dev : Depends: libaec-dev but it is not going to be installed
Depends: hdf5-helpers but it is not going to be installed
Depends: libhdf5-cpp-103 (= 1.10.4+repack-11ubuntu1) but it is not going to be installed
nvcv0-dev : Depends: libnvcv0 (>= 0.4) but it is not installable
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
nvidia@nvidia:~/Desktop/tensorrt/samples/python/efficientnet$ sudo apt-get install libnvcv0
Package libnvcv0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libnvcv0’ has no installation candidate
The command work well in our environment.
Could you try to run sudo apt update to see if it helps?
