Can't install pycuda
Good mooring. I have some problems with the installation of pycuda on ubuntu 22.04 with python 3.10.6 and NVIDIA GeForce RTX 3060 Laptop GPU.
I have installed cuda library, if I type the command
nvidia-smi
I get the usual frame displaying the driver version: NVIDIA-SMI 525.60.13 Driver Version: 525.60.13 CUDA Version: 12.0 .
Also, I have tried to run a simple cuda code and everything runs smoothly.
I have tried to install pycuda wit the following command -pip-
 pip install pycuda
Regrettably the procedure ends with the following error message -I attach only the final part since the whole message is huge-
     /usr/include/c++/11/bits/unique_ptr.h:57:28: note: declared here
         57 |   template<typename> class auto_ptr;
      In file included from bpl-subset/bpl_subset/boost/bind/bind.hpp:29,
                       from bpl-subset/bpl_subset/boost/bind.hpp:22,
                       from bpl-subset/bpl_subset/boost/thread/detail/thread.hpp:23,
                       from bpl-subset/bpl_subset/boost/thread/thread.hpp:22,
                       from bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp:11:
      bpl-subset/bpl_subset/boost/bind/arg.hpp: In constructor ‘pycudaboost::arg<I>::arg(const T&)’:
      bpl-subset/bpl_subset/boost/bind/arg.hpp:37:22: warning: typedef ‘T_must_be_placeholder’ locally defined but not used [-Wunused-local-typedefs]
         37 |         typedef char T_must_be_placeholder[ I == is_placeholder<T>::value? 1: -1 ];
      In file included from bpl-subset/bpl_subset/boost/thread/thread.hpp:24,
      bpl-subset/bpl_subset/boost/thread/detail/thread_group.hpp: In member function ‘pycudaboost::thread* pycudaboost::thread_group::create_thread(F)’:
      bpl-subset/bpl_subset/boost/thread/detail/thread_group.hpp:42:18: warning: ‘template<class> class std::auto_ptr’ is deprecated: use 'std::unique_ptr' instead [-Wdeprecated-declarations]
         42 |             std::auto_ptr<thread> new_thread(new thread(threadfunc));
      In file included from /usr/include/c++/11/memory:76,
                       from bpl-subset/bpl_subset/boost/move/move.hpp:38,
                       from bpl-subset/bpl_subset/boost/thread/detail/move.hpp:20,
                       from bpl-subset/bpl_subset/boost/thread/locks.hpp:11,
                       from bpl-subset/bpl_subset/boost/thread/pthread/thread_data.hpp:11,
                       from bpl-subset/bpl_subset/boost/thread/thread.hpp:17,
      bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp: In member function ‘bool pycudaboost::thread::do_try_join_until(const timespec&)’:
      bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp:379:5: warning: control reaches end of non-void function [-Wreturn-type]
        379 |     }
      x86_64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -fwrapv -Wall -O3 -DNDEBUG -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_MULTI_INDEX_DISABLE_SERIALIZATION=1 -DBOOST_PYTHON_SOURCE=1 -Dboost=pycudaboost -DBOOST_THREAD_DONT_USE_CHRONO=1 -DPYGPU_PACKAGE=pycuda -DPYGPU_PYCUDA=1 -DHAVE_CURAND=1 -Isrc/cpp -Ibpl-subset/bpl_subset -I/tmp/pip-build-env-sr08yzu7/overlay/local/lib/python3.10/dist-packages/numpy/core/include -I/usr/include/python3.10 -c src/cpp/bitlog.cpp -o build/temp.linux-x86_64-cpython-310/src/cpp/bitlog.o
      x86_64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -fwrapv -Wall -O3 -DNDEBUG -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_MULTI_INDEX_DISABLE_SERIALIZATION=1 -DBOOST_PYTHON_SOURCE=1 -Dboost=pycudaboost -DBOOST_THREAD_DONT_USE_CHRONO=1 -DPYGPU_PACKAGE=pycuda -DPYGPU_PYCUDA=1 -DHAVE_CURAND=1 -Isrc/cpp -Ibpl-subset/bpl_subset -I/tmp/pip-build-env-sr08yzu7/overlay/local/lib/python3.10/dist-packages/numpy/core/include -I/usr/include/python3.10 -c src/cpp/cuda.cpp -o build/temp.linux-x86_64-cpython-310/src/cpp/cuda.o
      In file included from src/cpp/cuda.cpp:4:
      src/cpp/cuda.hpp:14:10: fatal error: cuda.h: No such file or directory
         14 | #include <cuda.h>
      compilation terminated.
      error: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for pycuda
Failed to build pycuda
ERROR: Could not build wheels for pycuda, which is required to install pyproject.toml-based projects
I have already tried to use the following command but with no improvements:
 pip3 install pycuda
 pip install pycuda --user
Thank you for the time dedicated to read this post.
If this not the most relevant section, please move the topic in the most appropriate one.
Best regards.
Giovanni.
Good morning, I have solved the problem with the following instructions. I hope this can help others with the same problem in future:
$ export PATH=/usr/local/cuda/bin:$PATH
$ export CUDA_ROOT=/usr/local/cuda
$ pip install pycuda
Best regards.
Giovanni.
try pipwin install pycuda
I tried it and it didnt work.
This is my PATH:
/usr/local/cuda-11.8/bin
/home/iovi/anaconda3/envs/openmmlab/bin
/home/iovi/anaconda3/condabin
/usr/local/sbin
/usr/local/bin
/usr/sbin
/usr/bin
/sbin
/bin
/usr/games
/usr/local/games
/snap/bin
/snap/bin
I am getting the same error in my jetson orin nano. Did you find the solution for this error.
This isn’t optimal because the nvidia-official pypi distributions (IE nvidia-cudart-cu12) do not store all their shared and objects or headers under a shared /lib or /include path, which means you end up installing them twice with this method if you are using other python libraries that utilize the pypi dists (IE tensorrt, onnx, torch, tensorflow)
OR
You laboriously set all the CXXFLAGS, for every single one in the site-packages/nvidia dir.
OR
You can get away with just using --no-deps for some installs, but not for all.
Maybe you could try CUPY instead of PYCUDA.
I used Pycuda some time ago but installation was always complicated. CUPY is must easier to install and it is really interesting, powerful and easy to use.
Alain
