I’m trying to install nvidia drivers on Fedora 23 with Bumblebee and Bumblebee is installing an old driver as default which I don’t wanna use. So, I uninstall the old driver and bumblebee-nvidia and installed bumblebee-nvidia from unmanaged repo and copied new driver to ‘/etc/sysconfig/nvidia’.
Now its giving some errors as below.
bumblebee-nvidia --debug
WARNING: The symbolic link '/usr/lib/libGL.so.1' does not point to '/usr/lib64/nvidia-bumblebee/libGL.so.1' as is necessary for correct operation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64. It
is possible that `ldconfig` has created this incorrect symbolic link because libGL.so.1.2.0's "soname" conflicts with that of /usr/lib64/nvidia-bumblebee/libGL.so.1. It is recommended that you remove
or rename the file 'libGL.so.1.2.0' and create the necessary symbolic link by running `ln -sf /usr/lib64/nvidia-bumblebee/libGL.so.1 /usr/lib/libGL.so.1`.
ERROR: The runtime configuration check failed for the library 'libEGL.so.1' (expected: '/usr/lib/nvidia-bumblebee/libEGL.so.1', found: '/lib/libEGL.so.1'). The most likely reason for this is that conflicting
OpenGL libraries are installed in a location not inspected by `nvidia-installer`. Please be sure you have uninstalled any third-party OpenGL and/or third-party graphics driver packages.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download
page at www.nvidia.com.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue May 10 11:53:30 2016
installer version: 361.42
PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
--accept-license
--silent
--no-x-check
--no-nouveau-check
--no-recursion
--opengl-libdir=lib64/nvidia-bumblebee
--opengl-prefix=/usr
--x-library-path=lib64/nvidia-bumblebee
--x-prefix=/usr
--x-module-path=/usr/lib64/nvidia-bumblebee/xorg/modules
--compat32-libdir=lib/nvidia-bumblebee
--compat32-prefix=/usr
Using built-in stream user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> Tagging shared libraries with chcon -t textrel_shlib_t.
-> License accepted by command line option.
-> Installing NVIDIA driver version 361.42.
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Kernel source path: '/lib/modules/4.4.8-300.fc23.x86_64/source'
-> Kernel output path: '/lib/modules/4.4.8-300.fc23.x86_64/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.4.8-300.fc23.x86_64/source" SYSOUT="/lib/modules/4.4.8-300.fc23.x86_64/build"'...
rm -f -r conftest
/usr/bin/make "CC=cc" KBUILD_OUTPUT=/lib/modules/4.4.8-300.fc23.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.4.8-300.fc23.x86_64/source M=/tmp/NVIDIA-Linux-x86_64-361.42/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.4.8-300.fc23.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.4.8-300.fc23.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset" INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory '/usr/src/kernels/4.4.8-300.fc23.x86_64'
make[2]: Entering directory '/usr/src/kernels/4.4.8-300.fc23.x86_64'
make[2]: Leaving directory '/usr/src/kernels/4.4.8-300.fc23.x86_64'
make[1]: Leaving directory '/usr/src/kernels/4.4.8-300.fc23.x86_64'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.4.8-300.fc23.x86_64/source" SYSOUT="/lib/modules/4.4.8-300.fc23.x86_64/build"'...
/usr/bin/make "CC=cc" KBUILD_OUTPUT=/lib/modules/4.4.8-300.fc23.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.4.8-300.fc23.x86_64/source M=/tmp/NVIDIA-Linux-x86_64-361.42/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.4.8-300.fc23.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.4.8-300.fc23.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset" INSTALL_MOD_DIR=kernel/drivers/video modules
SYMLINK /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: vmap
CONFTEST: follow_pfn
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: change_page_attr
CONFTEST: set_memory_array_uc
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: drm_pci_set_busid
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_parse_phandle
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: hlist_for_each_entry
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: get_user_pages_unlocked
CONFTEST: dom0_kernel_present
CONFTEST: drm_available
CONFTEST: nvidia_grid_build
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-frontend.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-instance.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-acpi.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-cray.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-drm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-dma.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-gvi.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-i2c.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-mempool.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-mmap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-p2p.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-pat.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-procfs.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-usermap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-vm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-mlock.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-pci.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-registry.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-usermap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nvlink_pci.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/ebridge_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/ibmnpu_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_page_migration.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_page_migration_kepler.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_page_migration_pascal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_channel_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_perf.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_common_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_channel_directed_tests.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_kernel_events.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_kernel_counters.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_debug_session.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_gpu_ops_tests.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_lite.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_page_cache.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_lite_api.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_lite_prefetch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_lite_region_tracking.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_mmu_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_api.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_device_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_ctx_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_hashmap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_pa_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_unit_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_va_trie.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_pagetbl_mgmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/mmu_fmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/gmmu_fmt.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_fault_handler.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_identity_map.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm_full_perf.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_gpu_page_fault.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset/nvidia-modeset-linux.o
ld -r -o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-interface.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-frontend.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-instance.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-acpi.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-chrdev.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-cray.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-dma.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-drm.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-gvi.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-i2c.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-mempool.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-mmap.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-p2p.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-pat.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-procfs.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-usermap.o /tmp/
NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-vm.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-vtophys.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-interface.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-mlock.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-pci.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-registry.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/os-usermap.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv-modeset-interface.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nv_uvm_interface.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nvlink_linux.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/nvlink_pci.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/ebridge_linux.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia/ibmnpu_linux.o
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia.o
ld -r -o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset.o
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm.o
Building modules, stage 2.
MODPOST 3 modules
CC /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset.mod.o
CC /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm.mod.o
CC /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia.mod.o
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-uvm.ko
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia-modeset.ko
LD [M] /tmp/NVIDIA-Linux-x86_64-361.42/kernel/nvidia.ko
-> done.
-> Kernel module compilation complete.
-> Kernel messages:
[ 5047.427218] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 5047.427753] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 1
[ 5047.427759] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 361.42 Tue Mar 22 18:10:58 PDT 2016
[ 5047.435332] nvidia-uvm: Loaded the UVM driver in lite mode, major device number 242
[ 5047.436714] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 361.42 Tue Mar 22 17:29:54 PDT 2016
[ 5047.439046] nvidia-modeset: Unloading
[ 5047.448935] nvidia-uvm: Unloaded the UVM driver in lite mode
[ 5047.463783] nvidia-nvlink: Unregistered the Nvlink Core, major device number 243
[ 5047.463883] [drm] Module unloaded
[ 5055.952305] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=none
[ 5055.952382] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 5055.952668] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 1
[ 5055.952673] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 361.42 Tue Mar 22 18:10:58 PDT 2016
[ 8803.196565] nvidia-nvlink: Unregistered the Nvlink Core, major device number 243
[ 8803.196846] [drm] Module unloaded
[ 8839.326229] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=none
[ 8839.326335] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 8839.326725] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 1
[ 8839.326734] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 361.42 Tue Mar 22 18:10:58 PDT 2016
[ 8839.337158] nvidia-uvm: Loaded the UVM driver in lite mode, major device number 242
[ 8839.338993] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 361.42 Tue Mar 22 17:29:54 PDT 2016
[ 8839.340930] nvidia-modeset: Unloading
[ 8839.358237] nvidia-uvm: Unloaded the UVM driver in lite mode
[ 8839.369150] nvidia-nvlink: Unregistered the Nvlink Core, major device number 243
[ 8839.369297] [drm] Module unloaded
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> Will install non-GLVND GLX client libraries.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Checking for libglvnd installation.
Checking libGLdispatch...
Can't load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (361.42):
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-glcore.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/xorg/modules/extensions/libglx.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-tls.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/tls/libnvidia-tls.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGL.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLX_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libOpenGL.so.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLESv1_CM.so.1'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLESv2.so.2'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLdispatch.so.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libEGL.so.1'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/xorg/modules/drivers/nvidia_drv.so'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/xorg/modules/libnvidia-wfb.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk2.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk3.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-ml.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/vdpau/libvdpau_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libcuda.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-opencl.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libOpenCL.so.1.0.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-fatbinaryloader.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-ptxjitcompiler.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvcuvid.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-encode.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-ifr.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fbc.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-compiler.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-eglcore.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libnvidia-glsi.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libEGL_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLESv2_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/nvidia-bumblebee/libGLESv1_CM_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libcuda.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-fatbinaryloader.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-ptxjitcompiler.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-ml.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libOpenCL.so.1.0.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-compiler.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-opencl.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libOpenGL.so.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLdispatch.so.0'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLESv2.so.2'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLESv1_CM.so.1'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGL.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLX_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-glcore.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-tls.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/tls/libnvidia-tls.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/vdpau/libvdpau_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvcuvid.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-encode.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-eglcore.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-glsi.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libEGL.so.1'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libEGL_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLESv2_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libGLESv1_CM_nvidia.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-ifr.so.361.42'...
executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/nvidia-bumblebee/libnvidia-fbc.so.361.42'...
executing: '/usr/sbin/ldconfig'...
executing: '/usr/sbin/depmod -a '...
-> done.
-> Driver file installation is complete.
-> Running post-install sanity check:
WARNING: The symbolic link '/usr/lib/libGL.so.1' does not point to '/usr/lib64/nvidia-bumblebee/libGL.so.1' as is necessary for correct operation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64. It is possible that `ldconfig` has created this incorrect symbolic link because libGL.so.1.2.0's "soname" conflicts with that of /usr/lib64/nvidia-bumblebee/libGL.so.1. It is recommended that you remove or rename the file 'libGL.so.1.2.0' and create the necessary symbolic link by running `ln -sf /usr/lib64/nvidia-bumblebee/libGL.so.1 /usr/lib/libGL.so.1`.
-> done.
-> Post-install sanity check failed.
-> Running runtime sanity check:
ERROR: The runtime configuration check failed for the library 'libEGL.so.1' (expected: '/usr/lib/nvidia-bumblebee/libEGL.so.1', found: '/lib/libEGL.so.1'). The most likely reason for this is that conflicting OpenGL libraries are installed in a location not inspected by `nvidia-installer`. Please be sure you have uninstalled any third-party OpenGL and/or third-party graphics driver packages.
-> done.
-> Runtime sanity check failed.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
There was a person which he fixed the problem on 361.18 here: https://devtalk.nvidia.com/default/topic/885657/linux/can-t-install-driver-to-work-with-bumblebee-with-version-355-11/post/4786577/#4786577
I think he added --no-symlink-check and --no-runtime-check options in driver package and I’m wondering how can I do the same thing for 361.42 or is there any other solution for this.
