Tried with different driver-versions (510.73.05, 470.129.06).
Installation and usage of the driver is no problem but when running the -sanity
-check of the .run file it returns a non-zero retval (1) with the following message:
ERROR: The installed symbolic link '/usr/lib/x86_64-linux-gnu/libnvidia-vulka-producer.so' no longer exists.
When checking the given file, it is a link to a non-existant file libnvidia-vulkan-producer.so.[driver-version]
We already tried removing the dead-link before running the sanity-check but the error stays the same.
Anyone any idea? i guess we have to wait for nvidia to fix this or is there something we can do to make the sanity-check work?
It’s rather the question why the original library doesn’t get installed/vashishes.
The .manifest file at least contains it
libnvidia-vulkan-producer.so.510.73.05 0755 OPENGL_LIB NATIVE MODULE:egl
libnvidia-vulkan-producer.so 0000 UTILITY_LIB_SYMLINK NATIVE libnvidia-vulkan-producer.so.510.73.05 MODULE:egl
We install the driver via ./driver.run --no-wine-files -no-opengl-files --dkms -silent -e -k "${KVER}"
. @generix is the -no-opengl-files
problematic in that regard? (Note that we also used this installation for all previous driver-versions where we havn’t had this problem)
Ok, this explains it and also shows where the bug is. While the lib has type OPENGL_LIB so doesn’t get installed with no-opengl-files, the symlink has type UTILITY_LIB_SYMLINK so is treated as utility and gets wrongly installed. Should rather have type OPENGL_LIB_SYMLINK.
https://github.com/NVIDIA/nvidia-installer/blob/main/nvidia-installer.h#L106
Please send a mail to linux-bugs[at]nvidia.com since also the latest 515.48.07 driver contains this bug.
