i found this topic
that is a know issue with the current setup and there is a workaround, I should have mentioned that here
you need to place your widget that you need to interact with into a “dragable” placer
you placer need to be of fixed size and position so it wont have to move but it will enable the input system to reachout
with ui.Placer(draggable=True):
ui.Button("this Work")
if that doesn’t just fix it share a little more of the code around your widget and we will get you a solution
is this problem solved?
I’m not sure. I think that was in the context of widgets on the viewport. It might be better if you describe or share a code snippet of what you’re trying to do.
self._window = ui.Window("My Window", width=300, height=300)
with self._window.frame:
with ui.ZStack():
with ui.ScrollingFrame(
height=425,
horizontal_scrollbar_policy=ui.ScrollBarPolicy.SCROLLBAR_ALWAYS_OFF,
vertical_scrollbar_policy=ui.ScrollBarPolicy.SCROLLBAR_ALWAYS_ON,
with ui.VGrid(column_width=100, row_height=100):
for i in range(100):
with ui.ZStack():
ui.Rectangle(
style={
"border_color": 0xFF6A6A6A,
"background_color": 0xFFA8A8A8,
"border_width": 1,
"margin": 0,
ui.Label(f"{i}", style={"margin": 5})
with ui.VStack():
label = ui.Label("")
def on_click():
self._count += 1
label.text = f"count: {self._count}"
def on_reset():
self._count = 0
label.text = "empty"
on_reset()
with ui.HStack():
ui.Button("Add", clicked_fn=on_click)
ui.Button("Reset", clicked_fn=on_reset)
ui.Rectangle(width=80, style={"background_color": 0x220000FF})
the red Rectangle should be on the top
Thank you! I have two different approaches. I wonder which one applies more to what you want to do.
ZStack Rectangle over ScrollingFrame contents:
import omni.ui as ui
my_window = ui.Window("Example Window", width=300, height=300)
with my_window.frame:
with ui.ZStack():
height=425,
with ui.ZStack():
with ui.ZStack():
ui.Rectangle(
style={
"border_width": 1,
"margin": 0,
ui.Rectangle(height=ui.Percent(100), width=ui.Percent(50), style={"background_color": ui.color.red})
with ui.VStack():
OR Rectangle over ScrollingFrame:
with ui.ZStack():
height=425,
with ui.ZStack():
ui.Rectangle(
style={
"border_width": 1,
"margin": 0,
with ui.VStack():
Seems like the latter isn’t quite supported.
