I have been following a CUDA refresher course but have run into some trouble when trying to profile my code. If I compile the solution code and run nvprof ./matrix_sums, I get a profiling result as expected. However, if I try and add any metrics, e.g. nvprof --metrics gld_transactions ./matrix_sums, I get ==4481== NVPROF is profiling process 4481, command: ./matrix_sums ==4481== Error: Internal profiling error 4212:27. row sums correct! column sums correct! ======== Profiling result: No events/metrics were profiled. ======== Error: CUDA profiling error.
Looking up the error code in CUPTI suggests that it is CUPTI_ERROR_NOT_SUPPORTED, but it’s not clear exactly what isn’t supported. I have tried running with sudo and following the steps here so it does not appear to be a permission issue. My GPU is a 1080Ti and I am using the following software versions:
$ nvcc --version nvcc: NVIDIA (R) Cuda compiler driver Copyright (c) 2005-2025 NVIDIA Corporation Built on Tue_May_27_02:21:03_PDT_2025 Cuda compilation tools, release 12.9, V12.9.86 Build cuda_12.9.r12.9/compiler.36037853_0 $ nvprof --version nvprof: NVIDIA (R) Cuda command line profiler Copyright (c) 2012 - 2025 NVIDIA Corporation Release version 12.9.79 (21)
I don’t think newer versions (or Nsight Compute) support my GPU. My OS is Arch Linux. Any help would be very welcome!
My driver version is 580.82.09. Is it possible that this is too new? I haven’t frozen it like I have with the CUDA compiler and tools.
The sample is built with the 12.9 nvcc compiler
Here is the output for the commands you requested: $ nvprof -e inst_executed ./matrix_sums ======== Warning: Event "inst_executed" cannot be found on device 0. ==3605== NVPROF is profiling process 3605, command: ./matrix_sums row sums correct! column sums correct! ==3605== Profiling application: ./matrix_sums ==3605== Profiling result: No events/metrics were profiled. $ nvprof -m gld_efficiency,shared_efficiency ./matrix_sums ==3684== NVPROF is profiling process 3684, command: ./matrix_sums ==3684== Error: Internal profiling error 4212:27. row sums correct! column sums correct! ======== Profiling result: No events/metrics were profiled. ======== Error: CUDA profiling error.
