Cbb-fabric error when setting mtu
I’m running an Orin on a CTI Forge carrier that has 4 Ethernet ports. I have two of the Ethernet ports bridged together with the WiFi card. When I do that, however, the MTU on the bridged Ethernet ports drops to 1466, which causes problems with any two devices communicating through the bridge. To remedy this, I added a pre-up clause in the /etc/network/interfaces, to set the MTU of the bridged ports to 1534 like so
pre-up ip link set dev eqos0 mtu 1534
But I get this error, and then sometimes the bridge doesn’t come up:
[   17.541761] CPU:0, Error:cbb-fabric@0x13a00000, irq=21
[   17.541973] **************************************
[   17.542116] CPU:0, Error:cbb-fabric, Errmon:2
[   17.542265]    Error Code            : TIMEOUT_ERR
[   17.542386]    Overflow              : Multiple TIMEOUT_ERR
[   17.542549]
[   17.542595]    Error Code            : TIMEOUT_ERR
[   17.542711]    MASTER_ID             : CCPLEX
[   17.542812]    Address               : 0x23de008
[   17.542920]    Cache                 : 0x1 -- Bufferable
[   17.543049]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[   17.543259]    Access_Type           : Read
[   17.543365]    Access_ID             : 0x17
[   17.543366]    Fabric                : cbb-fabric
[   17.543581]    Slave_Id              : 0x35
[   17.543668]    Burst_length          : 0x0
[   17.543761]    Burst_type            : 0x1
[   17.543857]    Beat_size             : 0x2
[   17.543948]    VQC                   : 0x0
[   17.544099]    GRPSEC                : 0x7e
[   17.544103]    FALCONSEC             : 0x0
[   17.545163]    T234_CBB_SN_AXI2APB_35_BLOCK_TMO_STATUS : 0x1
[   17.546140]    T234_CBB_SN_AXI2APB_35_BLOCK0_TMO : 0x200
[   17.547071]  **************************************
[   17.547945] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:521 tegra234_cbb_err_isr+0x128/0x170
[   17.555123] ---[ end trace ee034b9152eeca32 ]---
please ifconfig down the interface before configuring the MTU.
Also, I don’t know anything about CTI board. If possible, please report this issue to the board vendor.
