Hello Everyone,
I am taking 4K@30 FPS raw stream from Camera Sensor and Putting it into the shmsink.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 do-timestamp=1 ! video/x-raw(memory:NVMM), width=3840, height=2160, format=(string)NV12, framerate=30/1 ! nvvidconv ! video/x-raw, width=(int)3840, height=(int)2160, format=(string)NV12 ! shmsink socket-path=abc_raw_stream.nv12 shm-size=50000000 sync=TRUE
I am using the same shmsink for multiple application. One of the Application is too stream camera over RTMP. But before stream I need to process every frame. So I passing that opencv capture and writer API.
OpenCV Capture Part from Shmsink
shmsrc socket-path=abc_raw_stream.nv12 do-timestamp=true ! video/x-raw, width=3840, height=2160, format=(string)NV12, framerate=30/1 ! nvvidconv ! video/x-raw(memory:NVMM), width=3840, height=2160, format=(string)NV12, framerate=30/1 ! nvvidconv ! video/x-raw, width=3840, height=2160, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink sync=true
OpenCV Writer Part for RTMP Stream
appsrc is-live=true ! video/x-raw, format=BGR ! queue ! videoconvert ! video/x-raw,format=RGBA ! nvvidconv ! nvv4l2h264enc profile=4 insert-sps-pps=true bitrate=1000000 ! video/x-h264 , stream-format=byte-stream ! h264parse ! flvmux ! rtmpsink location=rtmp_url/abcd
Now the Question is,
I want to take the 30fps Video from Camera Sensor. But Before Streaming it to Server using RTMP protocol, I want to reduce the Frame Rate either on Capture Side or Writer Side. For example 10fps. Is there a way by which this can be achieved ?
I am aware following till now,
- nvvidconv doesn’t support the framerate conversion options
- there are option like videorate and videoscale are there. But none of worked till now for me.
- Where shall I focus or debug more to put videorate or videoscale option ? Either on Capture Part of OpenCV or Writer Part of OpenCV ?
Any suggestions or pointers are appreciated in Advance.
Thanks & Regards,
xeqtr8041
