Change GPIO AON clock speed
I saw this post to change the GPIO clock speed:
How to do the same thing for AON GPIO ? And what is the maximum speed I can reach ?
Thank you
Hi jbzp00y,
Are you using the devkit or custom board for Orin NX?
Which GPIO would you like to control?
Hi @KevinFFF
I use a custom board with Jetpack 5.1.1.
I want to control those gpios:
  • JTAG_TMS: GPIO (Z.6)
  • JTAG_TCK: GPIO (Z.7)
  • JTAG_TDI: GPIO (CC.1)
  • JTAG_TDO: GPIO (X.7)
I made a comparison with a Jetson Nano on a custom carrier board and result are very different.
The test is the toggle of a gpio with gpiod in a Linux driver.
Jetson Nano: 7.29MHz
Jetson Orin NX: 240kHz
If I increase axi_cbb I can reach 380kHz on Orin NX but it’s far away from Nano. Do you have some idea to increase this speed ?
Jetson Nano and Orin Nano/NX are from different platform and also BSP release. The architecture and SW stack are so much different.
May I know what’s your use case for controlling GPIO with high speed?
Are you trying to transmitting some data through GPIO?
Yes, I flash a FPGA with bit-banging
It seems 380kHz is the expected result for Orin NX.
Do you consider for other approach for your use case to update FPGA firmware? (like JTAG or serial communication?)
I make JTAG with bit-banging. Is there any other way to perform this ?
We would suggest using serial communication instead of bit-banging to transmit data if the current performance of bit-banging can’t meet your requirement.
and sorry that we don’t have FPGA to verify it on the devkit.
It’s not possible to flash this FPGA with a serial communication.
So, it’s not possible to have the same performance on Orin NX that on Nano ?
There isn’t any hidden parameter ?
It may mainly relate to the SW stack difference between R32 and R35.
GPIO is available to be controlled for both release w/o other parameter to constraint its performance.
If you have Xavier, you could also compare the performance between R32 and R35.
