Clara AGX
Help Request: PyTorch / ONNX Compatibility on NVIDIA Clara AGX
I’m working with an NVIDIA Clara AGX system with the following specifications:
  • OS: Ubuntu 20.04.6 LTS (focal)
  • nvidia-l4t-core: Version 34.1.2-20221208104417
From what I understand, this setup is not officially tied to Jetson JetPack releases, so I don’t have a clear reference for software compatibility. Most online compatibility charts for PyTorch / ONNX are listed against JetPack versions, not directly for Clara AGX.
My questions:
  1. How can I determine which versions of PyTorch and ONNX Runtime are compatible with Clara AGX, given my environment?
  2. Is there a way to update the system so that compatibility information (normally tied to JetPack versions) applies here?
  3. If only pytorch 1.x is compatible with the Clara, is it better to keep my pytorch 2.3 that I built from source or use the latest compatible pytorch (i.e. 1.x)? My goal is to make a diffusion model run as fast as possible
What I’ve tried so far:
  • I successfully built PyTorch from source:
    • Version: 2.3.0a0+git63d5e92
    • CUDA arch: sm_75 (set TORCH_CUDA_ARCH_LIST="7.5;7.5+PTX")
    • Disabled: USE_FLASH_ATTENTION, USE_MEM_EFF_ATTENTION, USE_MKLDNN, USE_NCCL
