Clarification on NVAnalytics plugin
I am using nvanalytics and when I have the zones sometimes I see different bounding box colors for persons inside and outside the zone, In this case both the person inside and outside of the box have the same color. Generally I would see blue for person inside and red for person outside. How to understand this behavior?
Video: zone_issue
Zones config:
[roi-filtering-stream-0-0]
enable=1
roi-RF=153;50;490;49;530;179;124;252;66;152;153;50
inverse-roi=0
class-id=-1
• Hardware Platform (Jetson / GPU): Orin Nano Dev kit
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): 5.1.2
• TensorRT Version: 8.5.2.2
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
Thanks for the sharing! from the video, person 3 seemed to be in ROI because there was ROI label text. could you share the whole configuration file and test video? Thanks!
You can use forum private email. please click forum avatar-> personal messages->new message.
are you testing sample /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-nvdsanalytics-test?
