Hi. I’m running into issues trying to clean up when exiting application. Invoking rtContextDestroy causes error code 1280, with the following error text:
Invalid context (Details: Function “RTresult _rtContextDestroy(RTcontext)” caught exception: Encountered a CUDA error: cudaDriver().CuCtxGetCurrent( &context ) returned (4): Deinitialized
I’ve already confirmed that the context is created only once throughout the lifetime of the application, and it’s not destroyed multiple times.
I tried running rtDeviceGetDeviceCount when exiting, just out of curiosity, and it segfaults.
If I destroy the context earlier in the application (instead of upon exit), everything seems fine.
Anybody have any idea what might be happening?
I wish I had an example code to post, but for some reason I can’t reproduce the same problem with smaller applications or with any of SDK examples.
I’m using Ubuntu 16.04, Optix 5.1, display driver 396.45 if that helps.
