Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
[√] DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I don’t have the 5.2.0 source code on hand. Please check the capture.c file located at /home/jikuo/nvidia/nvidia_sdk/*/DRIVEOS/drive-oss-src/nvidia/drivers/media/platform/tegra/camera/vi/.
we can not find the capture.c file in your mentioned path. BTW, i find a similar capture-vi.c located at driveos/drive-oss-src/nvidia/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c. Could you help to find out if the problem exists?
Do you know why there was no call stack written in /var/log/syslog file when the problem happened? We only saw this error log, but no call stack.
I’m uncertain whether the absence of the call stack in the /var/log/syslog file is caused by specific logging configurations or another factor. To investigate, you can try invoking the same logging function that produces messages visible in the /var/log/syslog file.
