I’m trying to port my LI_M021C_MIPI camera driver to r28.1. Everything compiles and probes thanks to Shane, but nvcamerasrc/nvgstcapture fails in a strange way when I try to run it:
[ 732.072014] Unable to handle kernel NULL pointer dereference at virtual address 00000050
[ 732.080126] pgd = ffffffc07ce54000
[ 732.083696] [00000050] *pgd=00000000fcf3a003, *pud=00000000fcf3a003, *pmd=0000000000000000
[ 732.092054] Internal error: Oops: 96000046 [#1] PREEMPT SMP
[ 732.097610] Modules linked in:
[ 732.100663] CPU: 0 PID: 11361 Comm: nvcamera-daemon Not tainted 4.4.38+ #0
[ 732.107519] Hardware name: jetson_tx1 (DT)
[ 732.111602] task: ffffffc04566b200 ti: ffffffc02ec4c000 task.ti: ffffffc02ec4c000
[ 732.119070] PC is at tegra_camera_open+0x24/0x5c
[ 732.123674] LR is at tegra_camera_open+0x24/0x5c
[ 732.128277] pc : [<ffffffc0004c2488>] lr : [<ffffffc0004c2488>] pstate: 20000145
[ 732.135652] sp : ffffffc02ec4fb50
[ 732.138954] x29: ffffffc02ec4fb50 x28: 0000000000000000
[ 732.144263] x27: 0000000000000026 x26: ffffffc02a064900
[ 732.149572] x25: 0000000000000000 x24: ffffffc02a064910
[ 732.154881] x23: ffffffc000ba63a0 x22: ffffffc02a064900
[ 732.160190] x21: ffffffc0f9dd24d8 x20: 000000000000003c
[ 732.165498] x19: 0000000000000000 x18: 0000000000000011
[ 732.170807] x17: 0000007f79883250 x16: ffffffc0001c225c
[ 732.176116] x15: 0000007f7a261cc0 x14: 0000000000000000
[ 732.181425] x13: ffffffffffffffff x12: 0000000000000005
[ 732.186735] x11: 000000000000000a x10: fefefefefefefeff
[ 732.192044] x9 : 0000000000000000 x8 : ffffffc0d148dbb0
[ 732.197352] x7 : 0000000000000000 x6 : 0000000000000000
[ 732.202660] x5 : 0000000000000000 x4 : ffffffc02ec4c000
[ 732.207968] x3 : 0000000000000000 x2 : 0000000000000000
[ 732.213276] x1 : 0000000000000001 x0 : ffffffc00150a238
[ 732.220068] Process nvcamera-daemon (pid: 11361, stack limit = 0xffffffc02ec4c020)
[ 732.227617] Call trace:
[ 732.230055] [<ffffffc0004c2488>] tegra_camera_open+0x24/0x5c
[ 732.235700] [<ffffffc00055a300>] misc_open+0x160/0x1c4
[ 732.240825] [<ffffffc0001c7368>] chrdev_open+0xfc/0x1b4
[ 732.246036] [<ffffffc0001c0d4c>] do_dentry_open+0x1fc/0x310
[ 732.251593] [<ffffffc0001c1ddc>] vfs_open+0x68/0x78
[ 732.256457] [<ffffffc0001cff7c>] do_last+0x540/0x698
[ 732.261406] [<ffffffc0001d01a4>] path_openat+0xd0/0x140
[ 732.266615] [<ffffffc0001d255c>] do_filp_open+0x38/0x8c
[ 732.271825] [<ffffffc0001c219c>] do_sys_open+0x178/0x214
[ 732.277122] [<ffffffc0001c226c>] SyS_openat+0x10/0x18
[ 732.282161] [<ffffffc0000847f0>] el0_svc_naked+0x24/0x28
[ 732.287458] ---[ end trace 0d6f9e2bb5ec5839 ]---
The code doesn’t even get to my driver, it fails in tegra_camera_open from a null pointer dereference. I’m assuming there’s some subsystem I forgot to register with.
That function is located at kernel-4.4/drivers/video/tegra/camera/tegra_camera_platform.c
static int tegra_camera_open(struct inode *inode, struct file *file)
struct tegra_camera_info *info;
struct miscdevice *mdev;
mdev = file->private_data;
info = dev_get_drvdata(mdev->parent);
file->private_data = info;
#if defined(CONFIG_TEGRA_BWMGR)
/* get bandwidth manager handle if needed */
info->bwmgr_handle =
tegra_bwmgr_register(TEGRA_BWMGR_CLIENT_CAMERA);
/* set the initial rate */
if (IS_ERR_OR_NULL(info->bwmgr_handle)) {
info->bwmgr_handle = NULL;
return -ENODEV;
tegra_bwmgr_set_emc(info->bwmgr_handle, 0,
TEGRA_BWMGR_SET_EMC_SHARED_BW);
return 0;
#else
return tegra_camera_emc_clk_enable();
#endif
Anyone else run into this issue?
