Hi nvidia,
My camera output format is Bayer BGGR 12-bit as following:
When I set pixel_phase = "bggr" in dts, and insmod camer driver module, Kernel panic is happening.
[ 95.110755] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
[ 95.110762] Mem abort info:
[ 95.110764] ESR = 0x0000000096000004
[ 95.110766] EC = 0x25: DABT (current EL), IL = 32 bits
[ 95.110769] SET = 0, FnV = 0
[ 95.110770] EA = 0, S1PTW = 0
[ 95.110772] FSC = 0x04: level 0 translation fault
[ 95.110773] Data abort info:
[ 95.110774] ISV = 0, ISS = 0x00000004
[ 95.110776] CM = 0, WnR = 0
[ 95.110777] user pgtable: 4k pages, 48-bit VAs, pgdp=000000010a718000
[ 95.110781] [0000000000000000] pgd=0000000000000000, p4d=0000000000000000
[ 95.110790] Internal error: Oops: 0000000096000004 [#1] PREEMPT_RT SMP
[ 95.110795] Modules linked in: nv_ox03c10(OE+) nvidia_modeset(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink ip6table_nat ip6table_filter ip6_tables iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter br_netfilter lzo_rle lzo_compress zram zsmalloc bridge stp llc usb_f_ncm snd_soc_tegra186_asrc(O) snd_soc_tegra210_admaif(O) snd_soc_tegra210_mixer(O) snd_soc_tegra_pcm snd_soc_tegra210_ope(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_afc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_i2s(O) tegra210_adma snd_soc_tegra210_ahub(O) usb_f_acm u_serial spidev nvvrs_pseq_rtc(O) usb_f_rndis rfkill joydev u_ether cdc_acm ramoops reed_solomon snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) crct10dif_ce tegra234_oc_event(O) snd_soc_simple_card_utils tegra23x_perf_uncore(O)
[ 95.110874] nvpmodel_clk_cap(O) tegra_mce(O) mttcan(O) snd_hda_codec_hdmi thermal_trip_event(O) tegra_cactmon_mc_all(O) nvethernet(O) tegra234_aon(O) can_dev tegra_aconnect nvpps(O) phy_tegra194_p2u snd_soc_rt5640 snd_hda_tegra pwm_tegra_tachometer(O) snd_hda_codec snd_soc_rl6231 at24 snd_hda_core gpio_sgm4591q tegra_xudc spi_tegra114 i2c_nvvrs11(O) nvidia(O) lm90 mc_hwpm(O) host1x_fence(O) nvidia_vrs_pseq(O) pcie_tegra194 tegra_dce(O) nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) libcomposite tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) governor_userspace hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 tegra_drm(O) videobuf2_common videodev nvhost_pva(O) nvhost_nvdla(O) tegra_wmark(O) tsecriscv(O) mc nvhost_capture(O) cec tegra_se(O) nvhwpm(O) drm_kms_helper crypto_engine host1x_nvhost(O) nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O)
[ 95.110959] host1x(O) mc_utils(O) nvmap(O) drm nvsciipc(O) fuse ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal
[ 95.110977] CPU: 1 PID: 2380 Comm: insmod Tainted: G OE 5.15.136-rt-tegra #1
[ 95.110982] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[ 95.110985] pstate: a0400009 (NzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 95.110990] pc : camera_common_g_fmt+0x4c/0xb0 [tegra_camera]
[ 95.111029] lr : camera_common_g_fmt+0x30/0xb0 [tegra_camera]
[ 95.111056] sp : ffff8000142734c0
[ 95.111057] x29: ffff8000142734c0 x28: ffff0000aeee8c88 x27: 0000000000000038
[ 95.111063] x26: ffffca0ada3ab910 x25: ffffca0ada3ab900 x24: ffff00008e842ab8
[ 95.111067] x23: ffffca0ada305df0 x22: ffff0000d3f150b8 x21: ffff800014273578
[ 95.111071] x20: ffff0000866d0420 x19: ffff800014273608 x18: ffffffffffffffff
[ 95.111076] x17: 000000040044ffff x16: ffffca0b334d2f40 x15: ffff8000142734b8
[ 95.111080] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000027
[ 95.111084] x11: 0101010101010101 x10: ffff0000d3f15208 x9 : 7f7f7f7f7f7f7f7f
[ 95.111089] x8 : fefeff2f64636e6c x7 : 0000000001808080 x6 : 0000000100000000
[ 95.111093] x5 : 8080800000000000 x4 : 8000000000000000 x3 : 0000000000000001
[ 95.111097] x2 : ffff0000d3f15080 x1 : 0000000000000000 x0 : 0000000000000000
[ 95.111102] Call trace:
[ 95.111104] camera_common_g_fmt+0x4c/0xb0 [tegra_camera]
[ 95.111130] v4l2sd_get_fmt+0x30/0x40 [tegra_camera]
[ 95.111157] call_get_fmt+0x7c/0xa0 [videodev]
[ 95.111187] tegra_channel_fmts_bitmap_init+0x1b0/0x2b0 [tegra_camera]
[ 95.111215] tegra_channel_init_subdevices+0x18c/0x790 [tegra_camera]
[ 95.111241] tegra_vi_graph_notify_complete+0x2fc/0x670 [tegra_camera]
[ 95.111266] v4l2_async_notifier_try_complete.part.0+0x70/0x80 [v4l2_async]
[ 95.111274] v4l2_async_register_subdev+0x11c/0x1e0 [v4l2_async]
[ 95.111280] tegracam_v4l2subdev_register+0x104/0x180 [tegra_camera]
[ 95.111306] ox03c10_probe+0x118/0x168 [nv_ox03c10]
[ 95.111315] i2c_device_probe+0x2fc/0x340
[ 95.111326] really_probe.part.0+0xac/0x320
[ 95.111337] __driver_probe_device+0xa4/0x170
[ 95.111342] driver_probe_device+0x54/0x190
[ 95.111348] __driver_attach+0xa8/0x1b0
[ 95.111353] bus_for_each_dev+0x84/0xe0
[ 95.111357] driver_attach+0x38/0x50
[ 95.111362] bus_add_driver+0x118/0x210
[ 95.111367] driver_register+0x80/0x140
[ 95.111373] i2c_register_driver+0x5c/0xe0
[ 95.111377] ox03c10_i2c_driver_init+0x30/0x1000 [nv_ox03c10]
[ 95.111384] do_one_initcall+0x54/0x2e0
[ 95.111391] do_init_module+0x54/0x250
[ 95.111400] load_module+0x2148/0x2530
[ 95.111406] __do_sys_finit_module+0xa4/0xf0
[ 95.111412] __arm64_sys_finit_module+0x30/0x40
[ 95.111415] invoke_syscall+0x5c/0x130
[ 95.111422] el0_svc_common.constprop.0+0x64/0x110
[ 95.111428] do_el0_svc+0x74/0xa0
[ 95.111434] el0_svc+0x28/0x80
[ 95.111443] el0t_64_sync_handler+0xa4/0x130
[ 95.111446] el0t_64_sync+0x1a4/0x1a8
[ 95.111451] Code: 540002e0 f9401041 52800023 52800000 (b9400024)
[ 95.111458] ---[ end trace 0000000000000002 ]---
But when I set pixel_phase = "rggb" in dts, everything works fine, except that red and blue are swapped in images.
SDK release info is:
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
Appreciate your help.
