CodeworksforAndroid-1R7u1-windows.exe fails to download Android SDK
I’m trying to install the Android SDK for Windows, to use with Unreal. Unreal’s engine comes with this installer. It is failing – when trying to install Android SDK Base, it says Downloading (retry 10/10),before giving me the error “Downloading packages failed.”
How do I fix this? I am running as administrator.
I also facing the same problem, if any sloution you can share me.
I ended up getting mine from a fellow coworker. However he said that he had the same problem, and he just kept trying a bunch of times and it eventually worked. !?
