Coin Cell Battery charging disable
Just like you , even I was confused on the entire process of disabling the battery charging process, hence I took a better approach of purchasing a rechargeable battery altogether. Check out the battery model BR1225. it is similar to CR1225 that is recommended in the manual. It should work fine.
